[OpenLayers-Dev] mobile-jq example does not work with current jQuery Mobile (was: Current and Future jQuery mobile will not work with OpenLayers.)
Volker Mische volker.mische at gmail.com
Fri Jul 22 21:42:43 EDT 2011
Another workaround is to use jQuery functions to get the size of the
map. Just put this after OpenLayers.js is loaded:
     OpenLayers.Map.prototype.getCurrentSize = function() {
         var mapDiv = $(this.div);
         return new OpenLayers.Size(mapDiv.width(), mapDiv.height());
Cheers,
   Volker
On 07/22/2011 06:37 PM, Volker Mische wrote:
> Hi all,
> reviving an old thread. I just ran into the issue. The problem is that
> OpenLayers doesn't calculate the size of hidden elements (display:none)
> correctly, but jQuery mobile hides the element that contains
> data-role"page". The solution for this problem is to set the element and
> all its parents (if they are hidden as well) to
> display:block;position:absolute;visibility:hidden.
> You can read more about the problem and its solution here [1] and in the
> jQuery source code [2] (search for showCss).
> [1]
> http://www.foliotek.com/devblog/getting-the-width-of-a-hidden-element-with-jquery-using-width/
> [2]
> https://github.com/jquery/jquery/blob/124817e6684086ccf74e509309b73d4b4dd89932/src/css.js
> A workaround for jQuery Mobile 1.0b1 is to add to the element that
> contains data-role="page" a css class named "ui-page-active"
> Should we incorporate a way to calculate the size of hidden elements
> into OpenLayers?
> Cheers,
> Volker
> On 07/12/2011 02:11 AM, Andreas Hocevar wrote:
>> Hi Noli,
>> the subject of this thread adds a lot of drama to to the content that
>> is not actually there. So I changed the subject. Anybody is welcHiome to
>> fix the mobile-jq example. A non-working example does not mean that
>> OpenLayers is broken.
>> Regards,
>> Andreas.
>> On Tue, Jul 12, 2011 at 10:43 AM, Noli Sicad<nsicad at gmail.com> wrote:
>>> Hi Andreas,
>>> I just tested the official jQuery Mobile example in OL 2.11 RC1.
>>> It is not working with the beta1 jQM release.
>>> You can download.
>>> 1.I am using mobile-jq.html in OpenLayers-2.11-rc1.tar.gz
>>> http://www.openlayers.org/download/
>>> 2. jQuery Mobile --- Zip File: jquery-mobile-1.0b1.zip (JavaScript,
>>> CSS, and images)
>>> http://jquerymobile.com/download/
>>> 3. jQuery 1.6.2
>>> http://docs.jquery.com/Downloading_jQuery
>>> The jquery mobile 1.0b1pre is working after this version. It is not
>>> working.
>>> Noli
>>> On 7/12/11, Andreas Hocevar<ahocevar at opengeo.org> wrote:
>>>> Can we have a link to an example that shows the issue, which uses
>>>> unminified versions of both OpenLayers and jQuery? This will make it
>>>> easier to locate the issue.
>>>> Thanks,
>>>> Andreas.
>>>> On Mon, Jul 11, 2011 at 5:43 AM, Noli Sicad<nsicad at gmail.com> wrote:
>>>>> Hi,
>>>>> I like to inform everybody that the current and future releases of
>>>>> jQuery Mobile will not work with OL until this issue is resolved.
>>>>> https://github.com/jquery/jquery-mobile/issues/search?q=OpenLayers
>>>>> If you know what is causing the problem, please let us.
>>>>> Noli
>>>>> _______________________________________________
>>>>> Dev mailing list
>>>>> Dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>>> Andreas Hocevar
>>>> OpenGeo - http://opengeo.org/
>>>> Expert service straight from the developers.
>>> Dev mailing list
More information about the Dev mailing list
