[OpenLayers-Dev] 2.10 and 2.11-RC1 OpenLayers.Class behavior
changes
Andreas Hocevar
ahocevar at opengeo.org
Sun Jul 24 17:38:15 EDT 2011
Hi Didier,
not sure if you've seen my follow-up mail. You need to re-assign the protoype after the snippet I posted. So the whole snippet would be:
var X= OpenLayers.Class({
initialize:function() { this._p= "A.initialize";
OpenLayers.Console.info(this._p); },
pa:"PA",
p_:null,
ma:function() { OpenLayers.Console.info("A.ma="+this.pa); }
xProto = X.prototype;
xProto.initialize = function() { this.p_= "A.initialize-new";
OpenLayers.Console.info(this.p_); }
X = xProto.initialize;
X.proto = xProto;
Note the last line.
Andreas.
On Jul 24, 2011, at 23:34 , RICHARD Didier wrote:
>> Hi Richard,
>> you are right of course, my bad. You would have to re-assign the prototype
>> of the old class, which gets lost when you re-assign X. Something like
>> pa:"PA",
>> p_:null,
> It does still not make the trick (same exception arisen in both 2.10 et 2.11)
>> Andreas.
>> On Jul 24, 2011, at 23:05 , RICHARD Didier wrote:
>>>> Hey Schuyler,
>>>> I'm not concerned about breaking backwards compatibility here. We never
>>>> encouraged people to override the initialize method by re-assigning it
>>>> on
>>>> the prototype, and we always advertised the initialize method as
>>>> constructor. With 2.11, finally, the initialize method is a real
>>>> constructor, i.e.
>>>> X.prototype.initialize === X.
>>>> So instead of
>>>> X.prototype.initialize = function() { ... }
>>>> which we never encouraged people to do anyway, people could now do
>>>> X = X.prototype.initialize = function() { ... }
>>> Thanks for remining this, but what about the new paradigm. Doing :
>>> pa:"PA",
>>> p_:null,
>>> X = X.prototype.initialize = function() { this.p_= "A.initialize-new";
>>> try {
>>> var x1= new X();
>>> OpenLayers.Console.assert((x1 instanceof X));
>>> OpenLayers.Console.assert((x1.p_=="A.initialize-new"));
>>> x1.ma();
>>> } catch(ex) {
>>> OpenLayers.Console.warn(ex);
>>> gives :
>>> TypeError: x1.ma is not a function
>>> It does not although work with 2.10 (same exception).
>>> Did I miss something ?
>>> didier
>>>> Andreas.
>>>> On Jul 24, 2011, at 22:07 , Schuyler Erle wrote:
>>>>> On Jul 24, 2011, at 4:43 AM, RICHARD Didier wrote:
>>>>>> With 2.10, overloading constructors was as simple as overwriting the
>>>>>> initialize prototype :
>>>>>> X.prototype.initialize= function () { ...}
>>>>>> In 2.11-RC1, it breaks as the new prototype is not the constructor !
>>>>>> BTW, as this new OpenLayers.Class is a major change in OpenLayers,
>>>>>> don't
>>>>>> you thing it is more a 3.0 feature than a 2.x ?
>>>>> I confess I'm a little concerned about this... Are we breaking
>>>>> backwards
>>>>> compatibility with such a change?
>>>>> SDE_______________________________________________
>>>>> Dev mailing list
>>>>> Dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>>> Andreas Hocevar
>>>> OpenGeo - http://opengeo.org/
>>>> Expert service straight from the developers.
>>> RICHARD Didier - Chef du pôle technique du Géoportail
>>> 2/4, avenue Pasteur - 94165 Saint Mandé Cedex
>>> Tél : +33 (0) 1 43 98 83 23
>>> Dev mailing list
>> Andreas Hocevar
> Dev mailing list
Andreas Hocevar
More information about the Dev
