[OpenLayers-Dev] 2.10 and 2.11-RC1 OpenLayers.Class behavior changes
Andreas Hocevar ahocevar at opengeo.org
Sun Jul 24 17:46:41 EDT 2011
Hi Didier,
what I showed you in the last snippet is exactly what happens in OpenLayers.Class. So to do it the way we recommend, and if you're into anonymous functions, you could do something like the following, which is 100% OpenLayers API compliant:
var X = OpenLayers.Class({
    initialize: function() {
        this._p = "A.initialize";
        OpenLayers.Console.info(this._p);
    ma: function() {
var x1 = new (OpenLayers.Class(X, {
        this._p = "A.initialize-new";
        OpenLayers.Console.info(this.p_);
Andreas.
On Jul 24, 2011, at 23:42 , RICHARD Didier wrote:
>> Sorry, missed to add the last line. So the working example would be:
>> var X= OpenLayers.Class({
>>   initialize:function() { this._p= "A.initialize";
>> OpenLayers.Console.info(this._p); },
>>   pa:"PA",
>>   p_:null,
>>   ma:function() { OpenLayers.Console.info("A.ma="+this.pa); }
>> xProto = X.prototype;
>> xProto.initialize = function() { this.p_= "A.initialize-new";
>> OpenLayers.Console.info(this.p_); }
>> X = xProto.initialize;
>> X.prototype = xProto;
> Great, it's now working (sorry for having replied too fastly to your
> previous email).
> I will try to write a method that propagate such overload to a full
> classes tree. My tests look like ;
>    A= OpenLayers.Class({
>        pa:"PA",
>        p_:null,
>    A.B= OpenLayers.Class(A,{
>        pa:"PA-bis",
>        pb:"PB",
>        mb:function() { OpenLayers.Console.info("B.mb="+this.pa+"
> "+this.pb); }
>    A.B.D= OpenLayers.Class(A.B,{
>        initialize:function() { this._p= "D.initialize";
>    A.B.E= OpenLayers.Class(A.B,{
>        initialize:function() { this._p= "E.initialize";
>    A.C= OpenLayers.Class(A,{
>        initialize:function() { this._p= "C.initialize";
>        pc:"PC",
>        ma:function() { OpenLayers.Console.info("C.ma="+this.pa+"
> "+this.pc); }
>    A.C.F= OpenLayers.Class(A.C,{
>        pf:"PF",
>        mf:function() { OpenLayers.Console.info("F.mf="+this.pa+"
> "+this.pc+" "+this.pf); }
>    A.C.G= OpenLayers.Class(A.C,{
>        pg:"PG",
>        ma:function() { OpenLayers.Console.info("G.ma="+this.pa+"
> "+this.pc+" "+this.pg); }
>    OpenLayers.overload= function(P,F) {
>    A= OpenLayers.overload(A, {
>        initialize:function() { this.p_= "A.initialize-new";
> OpenLayers.Console.info(this.p_); },
>        pa:"PA-new"
>    OpenLayers.Console.log("==============================================
> overloading A:");
>    OpenLayers.Console.log("A:");
>    try {
>        var a2= new A();
>        OpenLayers.Console.assert((a2 instanceof A));
>        OpenLayers.Console.assert((a2.p_=="A.initialize-new"));
>        a2.ma();
>    } catch(exa) {
>        OpenLayers.Console.warn(exa);
>    OpenLayers.Console.log("A.B:");
>    try {
>        var b2= new A.B();
>        OpenLayers.Console.assert((b2 instanceof A));
>        OpenLayers.Console.assert((b2 instanceof A.B));
>        OpenLayers.Console.assert((b2.p_=="A.initialize-new"));
>        b2.ma();
>        b2.mb();
>    } catch(exb) {
>        OpenLayers.Console.warn(exb);
>    OpenLayers.Console.log("A.B.D:");
>    try {
>        var d2= new A.B.D();
>        OpenLayers.Console.assert((d2 instanceof A));
>        OpenLayers.Console.assert((d2 instanceof A.B));
>        OpenLayers.Console.assert((d2 instanceof A.B.D));
>        OpenLayers.Console.assert((d2.p_=="D.initialize"));
>        d2.ma();
>        d2.mb();
>    } catch(exd) {
>        OpenLayers.Console.warn(exd);
>    OpenLayers.Console.log("A.B.E:");
>    try {
>        var e2= new A.B.E();
>        OpenLayers.Console.assert((e2 instanceof A));
>        OpenLayers.Console.assert((e2 instanceof A.B));
>        OpenLayers.Console.assert((e2 instanceof A.B.E));
>        OpenLayers.Console.assert((e2.p_=="E.initialize"));
>        e2.ma();
>        e2.mb();
>    } catch(exe) {
>        OpenLayers.Console.warn(exe);
>    OpenLayers.Console.log("A.C:");
>    try {
>        var c2= new A.C();
>        OpenLayers.Console.assert((c2 instanceof A));
>        OpenLayers.Console.assert((c2 instanceof A.C));
>        OpenLayers.Console.assert((c2.p_=="C.initialize"));
>        c2.ma();
>    } catch(exc) {
>        OpenLayers.Console.warn(exc);
>    OpenLayers.Console.log("A.C.F:");
>    try {
>        var f2= new A.C.F();
>        OpenLayers.Console.assert((f2 instanceof A));
>        OpenLayers.Console.assert((f2 instanceof A.C));
>        OpenLayers.Console.assert((f2 instanceof A.C.F));
>        OpenLayers.Console.assert((f2.p_=="C.initialize"));
>        f2.ma();
>        f2.mf();
>    } catch(exf) {
>        OpenLayers.Console.warn(exf);
>    OpenLayers.Console.log("A.C.G:");
>    try {
>        var g2= new A.C.G();
>        OpenLayers.Console.assert((g2 instanceof A));
>        OpenLayers.Console.assert((g2 instanceof A.C));
>        OpenLayers.Console.assert((g2 instanceof A.C.G));
>        OpenLayers.Console.assert((g2.p_=="C.initialize"));
>        g2.ma();
>    } catch(exg) {
>        OpenLayers.Console.warn(exg);
>    OpenLayers.Console.log("done!");
> The method has to work in both 2.10 and 2.11 in the end ...
> regards,
> didier
>> Andreas.
>> On Jul 24, 2011, at 23:17 , Andreas Hocevar wrote:
>>> Hi Richard,
>>> you are right of course, my bad. You would have to re-assign the
>>> prototype of the old class, which gets lost when you re-assign X.
>>> Something like
>>>  pa:"PA",
>>>  p_:null,
>>> Andreas.
>>> On Jul 24, 2011, at 23:05 , RICHARD Didier wrote:
>>>>> Hey Schuyler,
>>>>> I'm not concerned about breaking backwards compatibility here. We
>>>>> never
>>>>> encouraged people to override the initialize method by re-assigning it
>>>>> on
>>>>> the prototype, and we always advertised the initialize method as
>>>>> constructor. With 2.11, finally, the initialize method is a real
>>>>> constructor, i.e.
>>>>> X.prototype.initialize === X.
>>>>> So instead of
>>>>> X.prototype.initialize = function() { ... }
>>>>> which we never encouraged people to do anyway, people could now do
>>>>> X = X.prototype.initialize = function() { ... }
>>>> Thanks for remining this, but what about the new paradigm. Doing :
>>>>  pa:"PA",
>>>>  p_:null,
>>>> X = X.prototype.initialize = function() { this.p_= "A.initialize-new";
>>>> try {
>>>>  var x1= new X();
>>>>  OpenLayers.Console.assert((x1 instanceof X));
>>>>  OpenLayers.Console.assert((x1.p_=="A.initialize-new"));
>>>>  x1.ma();
>>>> } catch(ex) {
>>>>  OpenLayers.Console.warn(ex);
>>>> gives :
>>>> TypeError: x1.ma is not a function
>>>> It does not although work with 2.10 (same exception).
>>>> Did I miss something ?
>>>> didier
>>>>> Andreas.
>>>>> On Jul 24, 2011, at 22:07 , Schuyler Erle wrote:
>>>>>> On Jul 24, 2011, at 4:43 AM, RICHARD Didier wrote:
>>>>>>> With 2.10, overloading constructors was as simple as overwriting the
>>>>>>> initialize prototype :
>>>>>>> X.prototype.initialize= function () { ...}
>>>>>>> In 2.11-RC1, it breaks as the new prototype is not the constructor !
>>>>>>> BTW, as this new OpenLayers.Class is a major change in OpenLayers,
>>>>>>> don't
>>>>>>> you thing it is more a 3.0 feature than a 2.x ?
>>>>>> I confess I'm a little concerned about this... Are we breaking
>>>>>> backwards
>>>>>> compatibility with such a change?
>>>>>> SDE_______________________________________________
>>>>>> Dev mailing list
>>>>>> Dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>>>> Andreas Hocevar
>>>>> OpenGeo - http://opengeo.org/
>>>>> Expert service straight from the developers.
>>>> RICHARD Didier - Chef du pôle technique du Géoportail
>>>> 2/4, avenue Pasteur - 94165 Saint Mandé Cedex
>>>> Tél : +33 (0) 1 43 98 83 23
>>>> Dev mailing list
>>> Andreas Hocevar
>> Andreas Hocevar
> Dev mailing list
Andreas Hocevar
More information about the Dev mailing list
