[OpenLayers-Dev] 2.10 and 2.11-RC1 OpenLayers.Class behavior
changes
Andreas Hocevar
ahocevar at opengeo.org
Thu Jul 28 06:36:25 EDT 2011
what about this:
var A = OpenLayers.Class({...});
var B = OpenLayers.Class(A, {...});
var OverloadB = {
initialize: function() {
alert("OverloadB");
customMethod: function() {...},
customProperty: "foo"
var proto = B.prototype;
B = OverloadB.initialize;
B.prototype = proto;
OpenLayers.Util.extend(B.prototype, OverloadB);
Andreas.
On Jul 28, 2011, at 11:27 , Richard Didier wrote:
> Le mercredi 27 juillet 2011 11:39:17, Richard Didier a écrit :
>> Le mardi 26 juillet 2011 11:52:10, Andreas Hocevar a écrit :
>>> Hi Richard,
>> Hi Andreas,
>>> Also, please let me know if you're able to override constructors in 2.11
>>> with this approach:
>>> OverloadB = {
>>> initialize: function() {...},
>>> var BTemp = OverloadB.initialize;
>>> BTemp.prototpye = B.prototype;
>>> OpenLayers.Util.extend(BTemp.prototype, OverloadB);
>>> B = BTemp;
>> Based on this, I have modified and tested overloading in both OL 2.10 and
>> OL 2.11 and its works for both ! The final code looks like (sure it can be
>> improved) :
>> * Function: OpenLayers.overload
>> * Apply the patch to the given class and propagate it downward
>> * to the sub-classes by insuring that only not overwritten
>> * methods() or properties are overloaded.
>> * Parameters:
>> * P - {Object} an instance of {<OpenLayers.Class>}
>> * F - {Object} an object used to overwrite methods (including
>> * constructor) and properties of P and its sub-classes.
>> * Returns:
>> * {Object} the overloaded instance of given {<OpenLayers.Class>}
>> OpenLayers.overload= function(P,F) {
>> Many thanks for your help.
> I wa a bit too enthusiast on this !(
> The fact is that with OL 2.11 an important part of the information seems to be lost when digging into the class
> hierarchy with Firebug :
> A= OpenLayers.Class(...);
> A.B= OpenLayers.Class(A, ...);
> In the end, one has :
> A
> B
> prototype
> initialize
> B
> When I applied my OpenLayers.overload method, I lost the second B in the initialize function() ... Although I still
> have B has an instanceof A, if I applied again the overload method, it does work anymore ...
> Reading the code (and to my understanding of this), it seems that the constructor does not "link" properly the B
> class with the A class when overriding the B class ...
> Any thought ?
> Regards,
> didier
>>> Andreas.
> RICHARD Didier - Chef du pôle technique du Géoportail
> 2/4, avenue Pasteur - 94165 Saint Mandé Cedex
> Tél : +33 (0) 1 43 98 83 23
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
