[OpenLayers-Dev] Why not have a transform method for geometry?
Pierre Giraud pierre.giraud at camptocamp.com
Tue Jun 7 05:22:21 EDT 2011
Do you mean that you were not abloe reproject geometries other than
bounds or point?
Actually, you can already use "transform" on any kind of geometry.
var format = new OpenLayers.Format.WKT();
var feature = format.read("POLYGON((-9.1054692864418
-4.2949220538139,-13.500000536442 0.97851544618607,-2.9531255364418
6.2519529461861,1.0898432135582 2.5605466961861,1.9687494635582
-3.7675783038139,-3.1289067864418 -0.77929705381393,-9.1054692864418
-4.2949220538139))");
feature.geometry.transform(new OpenLayers.Projection("EPSG:4326"), new
OpenLayers.Projection("EPSG:900913"));
Pierre
On Tue, Jun 7, 2011 at 1:29 AM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> It fairly inconvenient to project a geometry other than bounds or point.
> It looks to me like this would be good addition to the geometry class.
> Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
> Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
> Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Pierre GIRAUD
Géomaticien, Analyste
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 93
Mail : pierre.giraud at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
