[OpenLayers-Dev] What is right format for WKT in OpenLayers
(comma white space vs. comma)?
Noli Sicad
nsicad at gmail.com
Thu Jun 9 05:58:13 EDT 2011
This is the WKT OpenLayers example that the Spatialite query result won't work.
http://dev.openlayers.org/releases/OpenLayers-2.6/examples/wkt.html
How can modify this example to address this issue of having "comma white space"?
My spatial query will be also output in textarea prior to parsing as well.
Thanks.
Noli
On 6/9/11, Noli Sicad <nsicad at gmail.com> wrote:
> OK. I would want to debate about the standard.
> What need a parser that would be able to parse the comma white space
> from Spatialite query in order to render the feature in OpenLayers.
> Now, how we are going to modify this example using str.replace?
> function parseWKT() {
> var element = document.getElementById('wkt');
> var features = wkt.read(element.value);
> var bounds;
> if(features) {
> if(features.constructor != Array) {
> features = [features];
> for(var i=0; i<features.length; ++i) {
> if (!bounds) {
> bounds = features[i].geometry.getBounds();
> } else {
> bounds.extend(features[i].geometry.getBounds());
> vectors.addFeatures(features);
> map.zoomToExtent(bounds);
> var plural = (features.length > 1) ? 's' : '';
> element.value = 'Feature' + plural + ' added'
> } else {
> element.value = 'Bad WKT';
> Any ideas?
> Noli
> On 6/9/11, Trond Michelsen <trondmm-openlayers at crusaders.no> wrote:
>> On Thu, Jun 09, 2011 at 06:24:48PM +1000, Noli Sicad wrote:
>>> I ask this question a few hours ago about why the comma white space
>>> format of my LINESTRING would not work in Openlayers WKT example and
>>> I got the answer that my LINESTRING has wrong format i.e comma white
>>> space format.
>> Well, the official standard says:
>> http://www.opengeospatial.org/standards/sfa
>> <x> ::= <signed numeric literal>
>> <y> ::= <signed numeric literal>
>> <point> ::= <x> <y>
>> <left paren> ::= (
>> <right paren> ::= )
>> <comma> ::= ,
>> <space> ::= " "
>> <linestring text> ::= <empty set> | <left paren> <point> {<comma>
>> <point>}*
>> <right paren>
>> So, "space" is not explicitly mentioned to be allowed between the
>> comma and the point, but it's not explicitly mentioned between the x
>> and y values of the point either.
>> However, the standard also says:
>> <decimal point> ::= <period> | <comma>
>> So, both "5.4" and "5,4" must be accepted. If you omit the space
>> behind the comma, it'll be impossible to correctly parse a string like
>> this:
>> linestring(1,2 0,3,5 3,2)
>> Should this be parsed as
>> linestring(1.2 0.3, 5 3.2) or linestring(1.2 0, 3.5 3.2)?
>> So basically, the standard is a bit ambigous. A space in a definition
>> is optional or mandatory depending on where you find it.
>> Trond Michelsen
More information about the Dev
