[OpenLayers-Dev] Offline Tiles for OpenLayers -reading MbTiles offline in OpenLayers?
Noli Sicad nsicad at gmail.com
Thu Jun 9 21:24:00 EDT 2011
> If you use MapTiler to create the TMS directory, it automatically
> creates an openlayers.html file which combines the TMS with OSM, google,
> etc  and you can run this locally. It takes different approach and
> creates its own getTileURL. There are little gotchas regarding tile
> offsets etc depending on actual application usage but the code to find
> the url of right is so simple, its not hard to debug them.
OK. This is running  tile files *.png locally.
I will try to use it as well.
However, I am looking for offline Tile solution.
Thanks.
Noli
More information about the Dev mailing list
