[OpenLayers-Dev] SelectFeature with VML Renderer - _troot not
clickable
Alexandre Dube
adube at mapgears.com
Wed Jun 15 14:16:31 EDT 2011
Hello,
I already had the same problem. Setting the 'labelSelect' symbolizer
to true fixed the issue for me. See :
http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Feature/Vector-js.html
(look for 'labelSelect', under Symbolizer property).
HTH,
Alexandre
On 11-06-15 11:56 AM, Peter Körner wrote:
> Hi all,
> I'm working on displaying vector icons on a map. Unfortunately the map
> should work in IE as well. It does so, however the text on the vector
> icons is not clickable (ie they don't trigger a popup to be opened)
> whereas a click on the underlying image opens the popup as expected.
> The problem only affects the VML renderer.
> The click event is handled like this:
> map.addControl(
> new OpenLayers.Control.SelectFeature(jobsLayer, {
> autoActivate: true,
> onSelect: function(feature) {
> However onSelect is not called when a olv:textbox is clicked. I
> created a simple test case:
> http://maps.personalwerk.de/temp/select-bug.html
> In IE it's possible to click the circle but it's not the text, in
> Chrome or Firefox both can be clicked to trigger the alert-box.
> My questions are now:
> * is this a bug or a limitation of the VML renderer?
> * is this bug known and I just didn't find it?
> * where should I look for the bug in the source?
> I already took a brief look at VML.js but didn't find anything about
> events.
> I also looked at SelectFeature.js but didn't find a VML-only
> reference.
> Thank you all,
> Peter
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
