[OpenLayers-Dev] Submitted Patch for Ticket #2959
Tim Schaub tschaub at opengeo.org
Fri Jun 17 09:29:56 EDT 2011
On Thu, Jun 16, 2011 at 3:43 PM, Marc Jansen <jansen at terrestris.de> wrote:
> Hi all,
> indeed a great addition.
> I was wondering though wether we have all our @requires set correctly now.
> Or is OpenLayers.Util always included in custom builds?
Map.js requires Util.js - but I agree we should be more explicit about
our dependencies.
> And is there a reason that we do not have a test that explicitly checks the
> iframe-issue? I don't doubt it is being fixed by the patch but would love to
> have a test double checking that. Without actually trying I'd think that all
> current tests in test_isArray(t) would pass with the "old" and unwrapped
> instanceof as well.
I added a test to explicitly demonstrate where instanceof fails and
isArray works:
http://trac.osgeo.org/openlayers/changeset/12097
Good concerns.
Tim
> Just my two cents, thanks again and best regards,
> Marc
> Am 16.06.2011 21:19, schrieb Tim Schaub:
>> On 6/16/11 10:06 AM, Michael Wooten wrote:
>>> Hello All,
>>> I have submitted a patch for ticket #2959
>>> (http://trac.osgeo.org/openlayers/ticket/2959). The ticket is related
>>> to "instanceof Array" tests that fail when the array is passed from
>>> another frame or iframe (such as those used by Google Web Toolkit).
>>> The patch replaces the "x instanceof Array" tests with a new call to
>>> OpenLayers.Util.isArray(x). The OpenLayers.Util.isArray() function
>>> uses a test that should work across all frames. I also updated
>>> Util.html with a test case for isArray().
>>> Please consider this patch for review and inclusion in OpenLayers 2.11.
>> In with r12095.  Thanks for the great patch.
>> I think we need to restart the conversation about the 2.11 release
>> process.  This isn't a regression, so it shouldn't be pulled in during the
>> RC process.  But where we are in the process is not clear to me. Separate
>> thread.
>> Tim
>>> Thanks.
>>> -Michael Wooten
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Dev mailing list
Tim Schaub
OpenGeo http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
