[OpenLayers-Dev] Re: [OpenLayers-Users]
OpenLayers.Projection(OpenLayers.Util.getElement(......).value)
- jQuery problem
Noli Sicad
nsicad at gmail.com
Sat Jun 25 19:12:50 EDT 2011
I think the jQuery no conflict function could not be apply in this
case, since I am using jQuery mobile framework + Scrollview extension.
http://jquerymobile.com/
Just image changing all the $ to $j in jQuery Mobile framework, just
to make (OpenLayers.Util.getElement("inproj").value) working,
var $j = jQuery.noConflict();
Any other possible solution to get Util.js working in jQuery mobile.
Noli
On 6/25/11, Noli Sicad <nsicad at gmail.com> wrote:
> Thanks Nick for this info.
> Now, I have to replace $ into $j,
> I will try this option and see what happen.
> Now, how extended the use of prototype in OpenLayers?
> Is only Util.js uses prototype.js in OpenLayers?
> I saw OpenLayers.mobile.js uses as well Prototype.
> Noli
> On 6/25/11, Nick Kendall <n.e.kendall at gmail.com> wrote:
>> Try the jquery no conflict function
>> http://docs.jquery.com/Using_jQuery_with_Other_Libraries
>> Sent from my mobile device
>> On Jun 24, 2011, at 8:23 PM, Noli Sicad <nsicad at gmail.com> wrote:
>>> Hi,
>>> I am having problem executing this updateFormats function (below)
>>> which contains (OpenLayers.Util.getElement(......).value) in my jQuery
>>> mobile OL. The updateFormats is demonstrated in vector formats, in
>>> projection and out projection. My select controls are getting back
>>> when I clicked it.
>>> http://openlayers.org/dev/examples/vector-formats.html
>>> It seems that the problem is probably in the
>>> OpenLayers.Util.getElement(......) which a $.
>>> In Util.js,
>>> OpenLayers.Util.isElement = function(o) {
>>> return !!(o && o.nodeType === 1);
>>> * Maintain existing definition of $.
>>> if(typeof window.$ === "undefined") {
>>> window.$ = OpenLayers.Util.getElement;
>>> Is this intervening in jQuery? Could I delete this? What would be the
>>> solution inorder that updateFormats will be executed properly?
>>> Thanks in advance.
>>> Regards, Noli
>>> This updateFormats in jQuery.
>>> $(function() {
>>> function updateFormats() {
>>> alert("updated!");
>>> var in_options = {
>>> 'internalProjection': map.baseLayer.projection,
>>> 'externalProjection': new
>>> OpenLayers.Projection(OpenLayers.Util.getElement("inproj").value)
>>> alert(in_options);
>>> var out_options = {
>>> OpenLayers.Projection(OpenLayers.Util.getElement("outproj").value)
>>> var gmlOptions = {
>>> featureType: "feature",
>>> featureNS: "http://example.com/feature"
>>> var gmlOptionsIn = OpenLayers.Util.extend(
>>> OpenLayers.Util.extend({}, gmlOptions),
>>> in_options
>>> var gmlOptionsOut = OpenLayers.Util.extend(
>>> out_options
>>> var kmlOptionsIn = OpenLayers.Util.extend(
>>> {extractStyles: true}, in_options);
>>> formats = {
>>> 'in': {
>>> wkt: new OpenLayers.Format.WKT(in_options),
>>> geojson: new OpenLayers.Format.GeoJSON(in_options),
>>> gml2: new OpenLayers.Format.GML.v2(gmlOptionsIn),
>>> gml3: new OpenLayers.Format.GML.v3(gmlOptionsIn),
>>> kml: new OpenLayers.Format.KML(kmlOptionsIn)
>>> 'out': {
>>> wkt: new OpenLayers.Format.WKT(out_options),
>>> geojson: new OpenLayers.Format.GeoJSON(out_options),
>>> gml2: new OpenLayers.Format.GML.v2(gmlOptionsOut),
>>> gml3: new OpenLayers.Format.GML.v3(gmlOptionsOut),
>>> kml: new OpenLayers.Format.KML(out_options)
>>> $('#inproj, #outproj').change(updateFormats);
>>> }); // for the function
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
More information about the Dev
