[OpenLayers-Dev] click & pinch overhaul
Steven Ottens steven at minst.net
Mon Mar 7 14:57:03 EST 2011
Hi Cedric,
Technology moves fast apparently. I put the mailing-list back in, apparently someone is fixing stuff as we go along, so it is a good thing to keep them informed I guess :)
I just tested the links and my own (heavy) test site ( http://research.geodan.nl/ipad/MapQuery ) and your findings are correct. I guess since I tested the code it has been updated:
-Double tap works now in a very stable way, you can even move your finger a few centimeters between the taps and it is still recognized as a double tap.
-Two fingers tap is not working anymore. It did work though, not with 100% accuracy, but like 70%, when I sent my first mail out.
Also, not filled out in your spreadsheet is editing/drawing. I noticed that it works on my site, polygon, line and point, but some custom stuff we put in is not working properly so you get stuck with a popup and it is hard to test modification. It seems to fail, but not sure where the problem is.
Steven
On Mar 7, 2011, at 8:41 PM, Cédric MOULLET wrote:
> Hi Steven,
> These results are relative to the current trunk. I have added the line 30 for Tim's current works.
> - Two fingers tap - Zoom out doesn't work on http://goo.gl/hbEbp (I just tested on an iPad 4.2). Does it really work by you ?
> - Double tap - Zoom in does work http://goo.gl/hbEbp (I just tested on an iPad 4.2).
> Hope this clarifies.
> Cédric
> 2011/3/7 Steven Ottens <steven at minst.net>
> Hi Cedric,
> Nice spreadsheet!
> Quick question: 'iOS 4.2 iPad' and 'Two fingers tap zoom out' states 'error' is that correct? It works for me and double finger tap always worked for me.
> Steven
> On Mar 7, 2011, at 7:49 PM, Cédric MOULLET wrote:
> > Hi Tim,
> > Thanks for these improvements. I have tested on several plattforms (see https://spreadsheets.google.com/ccc?key=0AjTbLQNm01pfdEtUc0FkVm9DYnBtMTNkcWpTemw3T0E&authkey=CJGm_vQF&hl=fr#gid=0).
> > I face the same issues like Steven. In addition, I have observed the following things:
> > - iTouch 3.1.3: Pinch Zoom Dragging -> it moves the browser instead of the map and makes the function ineffective
> > - Android Nexus S: the double click seems to work a bit better, but has still issues. No idea why (but this is a very empirical observation)
> > - Chrome 10 - IE8 - FF3.6: dragging and double click are working fine (with mouse).
> > HTH,
> > Cédric
> > On Mon, Mar 7, 2011 at 5:58 PM, Steven M. Ottens <steven at minst.net> wrote:
> >  Hi Tim,
> >  Thanks for the update, comments inline.
> > On 3/7/2011 4:56 PM, Tim Schaub wrote:
> > Hey-
> > There are a number of issues with how the click and pinch handlers work together.  After adding pinch zoom, we lost the multi-touch click to zoom out.  In addition, the pinch handler was overly cautious about stopping event propagation because the click handler wasn't particularly good at distinguishing clicks from pinches.  I've overhauled the click handler to better distinguish clicks from pinches and resolved a number of issues that came up along the way.
> > There is no scroll-wheel support anymore, is this intentional. I know that's not a touch device, but still it would be nice so you could use the same client on all your platforms.
> > http://trac.osgeo.org/openlayers/ticket/3133
> > Andreas had reviewed this patch in a previous state, but there were still some unhandled errors getting through, so I continued to modify it.
> > I'd appreciate it if people could test the changes on real devices (I've only tested on emulators).  To best test the changes, it is important to have an error console enabled.
> > I tested the url below with an iPad with iOS 4.2.1 and its Safari browser.
> > You should see double-click (zoom in), multi-touch click (zoom out), and pinch (zoom/drag) working in this sandbox example (on multi-touch devices):
> > Pinch zoom works fast and without problems. Pinch-zoom-dragging (moving your two fingers over the device) is working as well correctly and doesn't produce the drag-error mentioned below. Multi-touch click works almost always, very rarely it gets mistaken for a pinch-gesture.
> > Double-click fails about 20%-60% of the time, without error. I tested it with a colleague and we think the problem is that it is hard to tap twice on exactly the same spot. As such a large 'buffer' area for the second tap would be advisable.
> > http://dev.openlayers.org/sandbox/tschaub/click/examples/mobile.html
> > You should also see no unhandled errors.  However, there are currently unhandled errors when dragging on the trunk (after r11635).  I'll update the sandbox when this is addressed.
> > I run in this error, while dragging. It didn't seem to impact performance or functionality. I take is the same as mentioned below:
> >  JavaScript Error on Line 195 in Drag.js
> > TypeError: Result of expression'evt' [null] is not an object
> > http://trac.osgeo.org/openlayers/ticket/2936#comment:17
> > I hope this helps a bit. In general I'm happy with the performance of the client on the iPad, apart from the double-tap issue it is a pleasure to use.
> > Regards,
> > Steven
> > Dev mailing list
> > Dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> > Political blog: http://cedricmoullet.blogspot.com/
> > Welcome to my world: http://www.cedricmoullet.com/
> > My Linked In profile: http://www.linkedin.com/in/cedricmoullet
> > Twitter: http://twitter.com/cedricmoullet
> > Home sweet home: http://map.geo.admin.ch/?crosshair=bowl&zoom=11&X=185241.24219&Y=561288.90625&bgOpacity=0&selectedNode=node_ch.swisstopo.fixpunkte-lage1
More information about the Dev mailing list
