[OpenLayers-Dev] click & pinch overhaul
Antoine Abt
antoine.abt at camptocamp.com
Mon Mar 7 16:08:06 EST 2011
On lundi 7 mars 2011 at 16:56, Tim Schaub wrote:
> I'd appreciate it if people could test the changes on real devices (I've
> only tested on emulators). To best test the changes, it is important to
> have an error console enabled.
> You should see double-click (zoom in), multi-touch click (zoom out), and
> pinch (zoom/drag) working in this sandbox example (on multi-touch devices):
> http://dev.openlayers.org/sandbox/tschaub/click/examples/mobile.html
> You should also see no unhandled errors. However, there are currently
> unhandled errors when dragging on the trunk (after r11635). I'll update
> the sandbox when this is addressed.
> http://trac.osgeo.org/openlayers/ticket/2936#comment:17
Tested on iphone(ios4.2).
I only see errors on dragging that should be fixed with previous patch.
Pinch and double-touch zoom out works like a charm. There's a few cases where double-click zoom-in doesn't work (let's say 10%), maybe when touches aren't too close, but it's still *very* usable at the moment.
Good work!
> Thanks for help testing/reviewing.
> Tim
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Antoine Abt
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 94
Mail : antoine.abt at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110307/adac6368/attachment.html
More information about the Dev
