[OpenLayers-Dev] Add support for mixed mode image tile caches
Joe Franklin
traderboy at yahoo.com
Thu Mar 10 10:25:16 EST 2011
Looking at the TMS, TileCache, WMTS classes (maybe others), the image extension is added to the url in the getURL function. What if you want to use a mixed mode cache that uses both PNG and JPEG? This option is useful for hi-res imagery caches that will be used as overlays. The border tiles use PNG32 so you can use transparency for the image edges, the inner tiles use JPEG which don't require transparency. The only change required for OpenLayers is to modify the getURL so it doesn't require a file extension.
Ex: http://myserver/tiles/0/0/0.png becomes http://myserver/tiles/0/0/0
Now the file 0 can be a PNG or a JPEG.
Here's part of what I posted at http://groups.google.com/group/mod-geocache:
Here's a simple solution to creating a multiple image format tile
cache. It works on a pre-seeded disk cache. The idea is simple:
replace all the png24 images with JPEG, leave the png32 images alone
(or optionally run pngcrush on them), then remove the file extensions
from all tiles so the client can access both without needing to know
their format/extension.
Requires: ImageMagick and pngcrush (both available using yum)
Run this in the root directory of your cached tile layer (ex: /tiles/
test2). I'm sure it can be written more cleverly, but it seems to
work. It reduced the size of my cache 58% by using both png and
jpegs.
for file in `find . -name "*.png"`;do
if [ -h $file ]; then
echo "Removing .png from symbolic link";
filename=${file%.*};
mv -f $file "$filename";
else
hasAlpha=`identify -verbose $file | grep Alpha`;
if [ "$hasAlpha" != "" ]; then
echo "Has alpha: $file";
#run pngcrush to reduce the size of the png
pngcrush -q -rem allb -brute "$file" tmp_img_file.png; \
mv -f tmp_img_file.png $file; \
#remove the .png extension
else
echo "No alpha: $file";
convert "$filename.png" "$filename.jpg";
#remove the .png file
rm -Rf $file
#remove the .jpg extension
mv -f "$filename.jpg" "$filename";
fi;
fi;
done;
ESRI's mixed mode image format for ArcGIS server where I swiped the idea:
(See pic on page 12 of http://proceedings.esri.com/library/userconf/cahinvrug10/papers/tech-sessions/arcgis_server_road_ahead.pdf)
More information about the Dev
