[OpenLayers-Dev] The Renderer.SVG2 may fail without Renderer.SVG
Andreas Hocevar ahocevar at opengeo.org
Fri Mar 11 21:32:05 EST 2011
Thanks Xavier, good catch. Fixed with r11700.
Andreas.
On Mar 11, 2011, at 17:06 , Xavier Mamano (jorix) wrote:
> Hi,
> Renderer.SVG2 use constants defined in Renderer.SVG (lines 619, 623 and 626)
> There is also an error in the documentation of "constructor" is mentioned
> Renderer.SVG, but must say Renderer.SVG2.
> Xavier Mamano
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-Renderer-SVG2-may-fail-without-Renderer-SVG-tp6163450p6163450.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
