[OpenLayers-Dev] Strange events on popup clicks
Martin Saturka
martin.saturka at sourcefabric.org
Wed Mar 16 08:55:42 EDT 2011
To recall the issue: when you click on a point popup, it closes that
popup and sends that click event into the map. It is so just after
some map / point / popup clicking, moving, ...
I tried to test it now (with the current dev OL lib), and
1) I can not see that bad behavior when the map is just for displaying
points and their bubbles.
2) The bad behavior is there regardless of the Bing things, and just
when I have event handling for new point creation, moving, ...
It looks kind of difference than it is at the stable 2.10 version (that we use).
Since it requires an amount of things there (and the dev version has a
different behavior than the stable one), I do not have a minimal
example yet.
M.
On Wed, Jan 5, 2011 at 10:09 PM, Martin Saturka
<martin.saturka at sourcefabric.org> wrote:
>>> 2) Putting the Bing layer into base layers causes event horrible
>>> problems. When I click on a pop-up window, that pop-up window takes it
>>> as a close event, and together with it puts a that clicking into the
>>> map, even though close events are ended at the pop-up closing methods.
>>> This mayhem only starts after some time (a few minutes) of map moving
>>> and poi / pop-up clicking, thus it may be a reason why it was not
>>> noticed.
>> Are you sure that this only happens with the Bing layer? Anyway, can you also please provide a minimal example that shows the issue?
> It only happens when the Bing layer is created and put into the map
> base layers. Then it happens, when a different base layer is used.
> When the Bing layer is not put into the map base layers (even when it
> is created), all is ok.
> I'm sorry, having a lack of time now, but I will test the previously
> mentioned patch, and will create an example (I hope at some few days).
Martin Saturka
Software Engineer, Sourcefabric
www.sourcefabric.org
More information about the Dev
