[OpenLayers-Dev] Re: Background Layer in EPSG:900913 causes WMS
overlays to fail
Kris Peterson
kris at mapbiquity.com
Thu Mar 17 23:14:59 EDT 2011
Hi Ulrik,
The maxExtent property of your map object needs to be set with appropriate
coordinates so that tile requests include the proper bounds. By default the
maxExtent property assumes a geographic projection (see
http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.maxExtent).
This is why your Request2 bounding box starts with -179 and -90. Include
something like:
maxExtent: new OpenLayers.Bounds(-20037508, -20037508, 20037508, 20037508)
in your map config options (this includes the whole world). So, for example,
your code might look something like this:
mapBroken900913 = new OpenLayers.Map
"mapBroken900913",
projection : "EPSG:900913",
maxResolution:2319.89824519781,
units:'m',
20037508)
Hope this helps.
Regards,
Kris
Kris Peterson
www.mapbiquity.com
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Background-Layer-in-EPSG-900913-causes-WMS-overlays-to-fail-tp6180162p6183276.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
