[OpenLayers-Dev] Re: Get the center and radius of a circle
chrisL
leipold at bi.bisnode.de
Tue Mar 22 06:55:34 EDT 2011
Hi Claudia,
your solution helped me a lot. Though I don't understand what unit radius
is. If I understood the docs correctly it should be the map's unit (which is
set to "m", which again should be meters). But the number I get doesn't make
any sense ... it seems not to be meters nor miles.
Can you give me a hint?
Thanks!
Chris
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Get-the-center-and-radius-of-a-circle-tp5790419p6195775.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
