[OpenLayers-Dev] PanZoomBar tries to zoom outside the range (plus
bad events)
Andreas Hocevar
ahocevar at opengeo.org
Thu Mar 24 06:45:08 EDT 2011
Can you please provide an example that shows the problem? The best place to do this (and attach a patch with your fixes) would be a ticket on http://trac.osgeo.org/openlayers/.
Thanks,
Andreas.
On Mar 16, 2011, at 13:14 , Martin Saturka wrote:
> Hi,
> when you drag the bar at the PanZoomBar too up or down, the control
> tries to zoom to levels outside the map zoom range, e.g. to -1 or 22,
> It would be nice if we had a hook for checking / modifying that
> targeted zoom number. We use some hook by now, as below at the
> "zoomBarUp" method.
> Together with it, the mouse click event stopping does not work
> correctly (at MSIE, and OL 2.10), thus we had to put some external
> dealing there (otherwise it ended up with adding new points as we have
> it for mouse click events).
> OpenLayers.Control.PanZoomBarMod =
> OpenLayers.Class(OpenLayers.Control.PanZoomBar, {
> // msie does not stops the event, and does not preserves its
> properties either
> divClick: function (evt) {
> if (!OpenLayers.Event.isLeftClick(evt)) {
> return;
> var levels = evt.xy.y / this.zoomStopHeight;
> if (this.forceFixedZoomLevel || !this.map.fractionalZoom) {
> levels = Math.floor(levels);
> var zoom = this.map.getNumZoomLevels() - 1 - levels;
> zoom = Math.min(Math.max(zoom, 0), this.map.getNumZoomLevels() - 1);
> this.map.zoomTo(zoom);
> var stop_event = OpenLayers.Hooks.PanZoomBar.divClick(this);
> if (stop_event)
> OpenLayers.Event.stop(evt);
> buttonDown: function(evt) {
> return;
> OpenLayers.Hooks.PanZoomBar.buttonDown(this);
> switch (this.action) {
> case "panup":
> this.map.pan(0, - this.getSlideFactor("h"));
> break;
> case "pandown":
> this.map.pan(0, this.getSlideFactor("h"));
> break;
> case "panleft":
> this.map.pan(- this.getSlideFactor("w"), 0);
> break;
> case "panright":
> this.map.pan(this.getSlideFactor("w"), 0);
> break;
> case "zoomin":
> this.map.zoomIn();
> break;
> case "zoomout":
> this.map.zoomOut();
> break;
> case "zoomworld":
> this.map.zoomToMaxExtent();
> break;
> default:;
> zoomBarUp: function(evt) {
> return;
> if (this.mouseDragStart) {
> this.div.style.cursor="";
> this.map.events.un({
> "mouseup": this.passEventToSlider,
> "mousemove": this.passEventToSlider,
> scope: this
> var deltaY = this.zoomStart.y - evt.xy.y;
> var zoomLevel = this.map.zoom;
> if (!this.forceFixedZoomLevel && this.map.fractionalZoom) {
> zoomLevel += deltaY/this.zoomStopHeight;
> zoomLevel = Math.min(Math.max(zoomLevel, 0),
> } else {
> zoomLevel += Math.round(deltaY/this.zoomStopHeight);
> var max_layer_zoom = OpenLayers.Hooks.Zooms.maxZoom(this);
> var min_layer_zoom = OpenLayers.Hooks.Zooms.minZoom(this);
> if ((max_layer_zoom !== undefined) && (typeof
> max_layer_zoom === "number")) {
> if (max_layer_zoom < zoomLevel) {zoomLevel = max_layer_zoom;}
> if ((min_layer_zoom !== undefined) && (typeof
> min_layer_zoom === "number")) {
> if (min_layer_zoom > zoomLevel) {zoomLevel = min_layer_zoom;}
> this.map.zoomTo(zoomLevel);
> this.mouseDragStart = null;
> this.zoomStart = null;
> var stop_event = OpenLayers.Hooks.PanZoomBar.zoomBarUp(this);
> if (stop_event) {
> CLASS_NAME: "OpenLayers.Control.PanZoomBar"
> M.
> Martin Saturka
> Software Engineer, Sourcefabric
> www.sourcefabric.org
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
