[OpenLayers-Dev] Re: 3d-accelerated panning
Xavier Mamano (jorix) xavier.mamano at gmail.com
Sun May 1 18:13:11 EDT 2011
Effectively, I tried using an HTC Magic with Android 2.2.1 and I have not
been able to see difference between using "?accel3d" and not use it.
NOTE: The anomaly mentioned by Nathan Gerber is a bug in the trunk, see
http://trac.osgeo.org/openlayers/ticket/3284
Xavier Mamano
Eric Lemoine-2-2 wrote:
> Hi
> I've been experimenting using CSS3 translate3d transform for moving
> the layer container div when panning. My experimental code is in the
> elemoine/accel3d sandbox.
> I would appreciate if IOS users could test [1] and [2] and report
> back, to know if my "3d-accelerated panning" code makes a difference.
> I'm also interested in feedback from Android users, although I don't
> expect better results with ?accel3d, since, to my knowledge, Android
> doesn't support 3D acceleration in the browser.
> Thanks,
> [1]
> <http://dev.openlayers.org/sandbox/elemoine/accel3d/examples/mobile-jq.html>
> [2]
> <http://dev.openlayers.org/sandbox/elemoine/accel3d/examples/mobile-jq.html?accel3d>
> (this one may yield a better map drag/pan experience in IOS/Safari)
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
View this message in context: http://osgeo-org.1803224.n2.nabble.com/3d-accelerated-panning-tp6317988p6322169.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
