[OpenLayers-Dev] OpenLayers with ExtJS 4
Dominik Mikiewicz dominikmikiewicz at o2.pl
Wed May 4 14:58:43 EDT 2011
Embeding an ol map within an extjs4 is as simple as when using extjs3. Same
applies to sencha touch. You just need a container you render a map to.
Making it work as a plugin takes a bit more time ;-)
-----Original Message-----
[mailto:openlayers-dev-bounces at lists.osgeo.org] On Behalf Of Luke Roth
Sent: Tuesday, May 03, 2011 7:36 PM
To: openlayers-dev at lists.osgeo.org
Subject: [OpenLayers-Dev] OpenLayers with ExtJS 4
Has anyone tried using OpenLayers with ExtJS 4?  I've been using
GeoExt to work with ExtJS 3, but I've looked through the source, and
it will take some time to port it to the new version.  Has anybody
done anything simpler (just embedding an OpenLayers map in an ExtJS4
page?)
If I get anywhere, I'll let you know what I find.
Luke
Dev mailing list
Dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
