[OpenLayers-Dev] SelectFeature and last/prevHighlighter
Eric Lemoine
eric.lemoine at camptocamp.com
Mon May 9 12:03:29 EDT 2011
On Monday, May 9, 2011, Slawomir Messner
<slawomir.messner at staff.uni-marburg.de> wrote:
> Hi,
> I have a question. In the unhighlight function if another SelectFeature was the prevHighlighter it is set to the lastHighlighter but then the feature is simply redraw with it's own style/layer style or default renderIntent. Shouldn't this be only in the first to cases of the if-stmt? in the third like in outFeature that the highlight of the "new" lastHighlighter is used?
> Here the code I'm talking about(Without the comments in it):
> unhighlight: function(feature) {
> var layer = feature.layer;
> if(feature._prevHighlighter == undefined) {
> delete feature._lastHighlighter;
> } else if(feature._prevHighlighter == this.id) {
> delete feature._prevHighlighter;
> } else {
> feature._lastHighlighter = feature._prevHighlighter;
> layer.drawFeature(feature, feature.style || feature.layer.style ||
> "default");
> this.events.triggerEvent("featureunhighlighted", {feature : feature});
> Now how I think it should be:
> var newHighlighter = null;
> } else {
> newHighlighter = this.map.getControl(feature._lastHighlighter);
> if(newHighlighter != null) {
> newHighlighter.highlight(feature);
> } else {
> "default");
> When I look at the code of highlight the "featureunhighlighted" should always thrown to a symmetric behavior of un-/highlight or the "featurehighlighted" event should only be triggered in the highlight when there was no _lastHighlighter.
Hi
I'd like to know your exact use-case (control1 does this, control2
does that, etc.). With that we should be able to write a test-case
demonstrating that the current code doesn't behave as expected.
Thanks for your effort on that. It's not trivial code.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
