[OpenLayers-Dev] doctype in examples
Eric Lemoine eric.lemoine at camptocamp.com
Mon May 30 10:57:02 EDT 2011
On Mon, May 30, 2011 at 4:36 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hey,
> it seems that with the XHTML doctype still used in many of our
> examples, IE9 does not do a good vector rendering job. It will choose
> the VML renderer, and do some things like label alignment really wrong
> (see http://openlayers.org/dev/examples/vector-features-with-text.html).
> When the doctype is changed to <!DOCTYPE HTML>, the same example
> renders perfectly well in IE9, using the SVG renderer.
> So my question: would developers agree to change the doctype of all
> our examples (at least the ones that continue to work fine after the
> change), and include this change in 2.11?
> I'm +1.
+1
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
