[OpenLayers-Dev] doctype in examples
christopher.schmidt at nokia.com
Mon May 30 13:48:15 EDT 2011
On May 30, 2011, at 12:45 PM, ext Tim Schaub wrote:
> On 5/30/11 8:57 AM, Eric Lemoine wrote:
>> On Mon, May 30, 2011 at 4:36 PM, Andreas Hocevar<ahocevar at opengeo.org> wrote:
>>> Hey,
>>> it seems that with the XHTML doctype still used in many of our
>>> examples, IE9 does not do a good vector rendering job. It will choose
>>> the VML renderer, and do some things like label alignment really wrong
>>> (see http://openlayers.org/dev/examples/vector-features-with-text.html).
>>> When the doctype is changed to<!DOCTYPE HTML>, the same example
>>> renders perfectly well in IE9, using the SVG renderer.
>>> So my question: would developers agree to change the doctype of all
>>> our examples (at least the ones that continue to work fine after the
>>> change), and include this change in 2.11?
>>> I'm +1.
>> +1
> Yes please.
I'm fine with that. I'll pull it up into 2.11.
-- Chris
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev
