[OpenLayers-Dev] Re: Features move around when map panned
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Mon May 30 15:18:23 EDT 2011
... No, this is not the issue.
To the OP: You need to use the sphericalMercator option on your commercial layers.
See http://openlayers.org/dev/examples/spherical-mercator.html .
-- Chris
On May 30, 2011, at 2:12 PM, ext amajedi wrote:
> try setting the 'isFixed' property in the vector layer to true
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Features-move-around-when-map-panned-tp6358063p6420102.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
