[OpenLayers-Dev] doctype in examples
christopher.schmidt at nokia.com
Tue May 31 11:22:34 EDT 2011
Thanks, Andreas!
-- Chris
On May 31, 2011, at 11:02 AM, ext Andreas Hocevar wrote:
> Ticketed as http://trac.osgeo.org/openlayers/ticket/3333, marked Pullup.
> Committed to trunk with http://trac.osgeo.org/openlayers/changeset/12032
> Andreas.
> On Mon, May 30, 2011 at 7:48 PM, <christopher.schmidt at nokia.com> wrote:
>> On May 30, 2011, at 12:45 PM, ext Tim Schaub wrote:
>>> On 5/30/11 8:57 AM, Eric Lemoine wrote:
>>>> On Mon, May 30, 2011 at 4:36 PM, Andreas Hocevar<ahocevar at opengeo.org> wrote:
>>>>> Hey,
>>>>> it seems that with the XHTML doctype still used in many of our
>>>>> examples, IE9 does not do a good vector rendering job. It will choose
>>>>> the VML renderer, and do some things like label alignment really wrong
>>>>> (see http://openlayers.org/dev/examples/vector-features-with-text.html).
>>>>> When the doctype is changed to<!DOCTYPE HTML>, the same example
>>>>> renders perfectly well in IE9, using the SVG renderer.
>>>>> So my question: would developers agree to change the doctype of all
>>>>> our examples (at least the ones that continue to work fine after the
>>>>> change), and include this change in 2.11?
>>>>> I'm +1.
>>>> +1
>>> Yes please.
>> I'm fine with that. I'll pull it up into 2.11.
>> -- Chris
>>> Tim Schaub
>>> OpenGeo - http://opengeo.org
>>> Expert service straight from the developers.
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Dev mailing list
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
More information about the Dev
