[OpenLayers-Dev] redraw(true) and random HTTP GET parameter with
XYZ Layer
JD
jdbrossillon at fly-n-sense.com
Fri Nov 4 12:58:31 EDT 2011
I try to force redraw of a XYZ layer on timeout using the redraw(true)
method on layer.
But it doesn't seems to do the trick, no random argument is added to
HTTP GET tiles requests.
After some time looking code I modified XYZ class.
http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Layer/XYZ.js
>From :
129 getURL: function (bounds) {
130 var xyz = this.getXYZ(bounds);
131 var url = this.url;
132 if (OpenLayers.Util.isArray(url)) {
133 var s = '' + xyz.x + xyz.y + xyz.z;
134 url = this.selectUrl(s, url);
135 }
136
137 return OpenLayers.String.format(url, xyz);
138 },
To :
131 var url = this.getFullRequestString();
135 }
136
138 },
It seems that random parameter added to class this.params are only
used by HTTPRequest::getFullRequestString and ignored by XYZ::getURL.
After some tests this modification seems to work fine.
Can you tell me if this is a genuine bug or I simply use the
OpenLayers API incorrectly ?
Thanks,
JD.
More information about the Dev
