[OpenLayers-Dev] v3 branch on GitHub for deprecation & API changes
Paul Spencer pagameba at gmail.com
Mon Nov 7 11:26:09 EST 2011
Advanced compilation adds type hinting/checking which can be useful as a smoke test when compiling.  It is laborious to implement the required comments to indicate types to the compiler, but once its in place it is pretty easy to continue using.  It also adds some very complex rules for code optimization and variable replacements - my experience is that it can be very tricky to work with when converting existing code.  I do not believe that it adds dynamic code loading, it might be work investigating require.js or some other commonjs module system.
I believe that closure has some code-quality checks, not sure if they are equivalent to JSHint or JSLint.  I think it is a great idea to include, though.
Someone did some work converting a minimal set of code to work with the advanced compiler a while ago, that's probably in the list archives somewhere if we want to take a look at it.  I think if we want to go this route, starting with the v3 overhaul is a great place because we can basically start from scratch and ensure that the API as a whole works with the advanced compilation settings from the beginning and add new stuff incrementally rather than starting with the extremely daunting task of reworking the entire existing code base.
Cheers
Paul
On 2011-11-07, at 11:05 AM, Tom MacWright wrote:
> I think it's worth a shot, though I'm kind of a newcomer to closure compiler - spending most time with uglify-js. I'd assume that the main benefit of advanced mode might be some kind of dynamic code-loading / externals concept? For code-quality, maybe we should take a look at JSHint or similar, as well?
> On Sun, Nov 6, 2011 at 3:33 PM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> My 0.0002c. Should v3 be aimed at being usable with advanced compilation
> with the google closure compiler as well?
> Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20111107/a7351b51/attachment.html
More information about the Dev mailing list
