[OpenLayers-Dev] Make short taps/clicks distinguishable from taphold/clickhold events in Handler.Click
Gregers Gram Rygg gregersrygg at gmail.com
Tue Nov 22 11:33:58 EST 2011
Thanks for looking at this. It's a common interaction in native map
applications, and might just as well be for web maps.
I agree with Tim that it should be possible to trigger "hold" before
"mouseup", so it's possible to give a visual feedback to the user that
they've hold their finger/mouse button down long enough.
Thanks,
Gregers
On Wed, Oct 26, 2011 at 10:33 PM, Tim Schaub <tschaub at opengeo.org> wrote:
> Looks very useful to me Marc.  And the changesets look reasonable at a glance.
> I understand your requirements might be different, but don't people
> typically respond to the "hold" before "mouseup" (or equivalent)?
> Tim
> On Thu, Oct 20, 2011 at 4:10 AM, Marc Jansen <jansen at terrestris.de> wrote:
>> Hi all,
>> we have currently the need to determine whether a captured click/tap on an
>> OpenLayers.Map was a short click/tap or was intended to be a "hold"
>> click/tap (One that lasted at the same location for a certain amount of
>> time).
>> I have working code in a sandbox [1] that shows what is intented behaviour
>> and also has a first rough implementation. My changes are the following
>> three changesets: [2], [3] & [4]. Here is an online example: [5]
>> How would you address this feature request? The code in the sandbox has no
>> new/adjusted tests yet.
>> I would love to hear whether this may be of need to the library as such, in
>> that case I would spend more time on finishing this task to create a
>> reviewable patch (e.g. tests, more documentation).
>> Best regards,
>> Marc
>> [1] http://dev.openlayers.org/sandbox/marcjansen/hold/ &
>> http://svn.openlayers.org/sandbox/marcjansen/hold/
>> [2] http://trac.osgeo.org/openlayers/changeset/12430
>> [3] http://trac.osgeo.org/openlayers/changeset/12431
>> [4] http://trac.osgeo.org/openlayers/changeset/12432
>> [5]
>> http://dev.openlayers.org/sandbox/marcjansen/hold/examples/mobile-hold.html
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Tim Schaub
> OpenGeo http://opengeo.org/
> Expert service straight from the developers.
> Dev mailing list
More information about the Dev mailing list
