[OpenLayers-Dev] A Quick Introduction
Andreas Hocevar ahocevar at opengeo.org
Thu Nov 24 15:55:50 EST 2011
Hey Landon,
welcome aboard! Thanks for your introduction. Sounds exciting. We look
forward to your contributions!
Make sure to check out the existing snapping features in OpenLayers
and the JSTS library, as these might provide some of the functionality
you need.
Andreas.
On Thu, Nov 24, 2011 at 8:28 PM, Landon Blake
<sunburned.surveyor at gmail.com> wrote:
> I wanted to make a quick introduction to the mailing list. Most of my
> programming experience has been on the desktop GIS program OpenJUMP.
> However, I recently started working with Javascript and OpenLayers for
> an application at my day job.
> I'm interested in contributing to OpenLayers as my knowledge of the
> library and Javascript improves. Ill be working soon on some tools to
> support route alignments and stationing as part of my web application
> that uses OpenLayers. (Example: Zoom to Station) Those tools may be
> useful to some others in the community.
> I also plan on releasing the code for my web map viewer, including the
> HTML and CSS, under an open source license.
> I'm downloading the source code for OpenLayers this weekend. If there
> is a specific feature in OpenLayers that could use some work from a
> rookie code slinger, I'd welcome suggestions.
> Thanks.
> Landon (AKA: The Sunburned Surveyor)
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
