[OpenLayers-Dev] Re: Gpx vector layer not displayed
Tobias Reinicke ramotswa at gmail.com
Fri Oct 7 07:03:08 EDT 2011
No there shouldn't be a difference. Try putting the full url into the
url:"" parameter.
Is the "gpx" folder on the same level as your "txt" folder? In which
case you need to put the "./" in front of the gpx path too...
Can you send me the full url?
Also, before one of the devs says it; this isn't really the correct
place for general usage questions.. these should really be in the
Openlayers-Users mailing list...
Toby
On 7 October 2011 11:58, nikolaHr <smetlishte at gmail.com> wrote:
> I have switch those two lines.
> I'm looking for an answer, and don't know why geting 404 (Not Found) on
> gpx/myosmfile.gpx.
> Locally everything is fine. I recently found about MIME type and httpd.conf,
> but that is for kml.
> Is there a diference in path locally and on server?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Gpx-vector-layer-not-displayed-tp6868869p6868905.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
