[OpenLayers-Dev] Re: How to find correct bounds to display an SVG at a correct location using addin inlineXhtml
hhudson hhudson at katmandu.org
Sat Oct 8 02:25:15 EDT 2011
If you are adding a scalable SVG image, you will need to specify the image
extent.  Depends how you created your SVG images in the first place - if the
SVG's are generated from spatial data/query you should know the extent when
you created the image.
Regards,
Harris.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-find-correct-bounds-to-display-an-SVG-at-a-correct-location-using-addin-inlineXhtml-tp6865466p6871934.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
