[OpenLayers-Dev] Export vector layer featuers as .kml and download that .kml file
mano3688 mano3688 at gmail.com
Thu Oct 13 06:38:49 EDT 2011
Hello sir,
           Now i trying to create .kml file but i don't how to create .kml
file and download that .kml file,Please tell me if you know anybody.I am
using wms and vector layer on the map.Features will be added when i click on
the map .
i want export vector layers as .kml file and how to download that file.
I write my partial code here,
map = new OpenLayers.Map('map');
			map.addControl(new OpenLayers.Control.LayerSwitcher());
			// create Google Mercator layers
		    googleLayer = new OpenLayers.Layer.Google("Google Streets Map",{
							 'sphericalMercator': true
			osmLayer = new OpenLayers.Layer.OSM("Open Street Map");
			stateLayer=new OpenLayers.Layer.WMS(
	        "States", "http://localhost:8080/geoserver/wms",
	        	layers: 'kcube:States',
	        	transparent: true,
	            styles: '',
	            format:'image/png',
	            tiled: 'true',
	            srs: 'EPSG:4326'
	        	buffer: 0,
	            isBaseLayer: false
		layer=stateLayer.name;
		var select = new OpenLayers.Layer.Vector("Selection");
		map.addLayers([googleLayer, osmLayer,stateLayer,select]);
		var control = new OpenLayers.Control.GetFeature({
			protocol: OpenLayers.Protocol.WFS.fromWMSLayer(stateLayer),
			multipleKey: "shiftKey",
			toggleKey: "ctrlKey"
		control.events.register("featureselected", this, function(e) {
				if(select.features.length)
					select.removeAllFeatures();
				select.addFeatures([e.feature]);
				 var kmlFormat = new OpenLayers.Format.KML(
									internalProjection:new OpenLayers.Projection("EPSG:900913"),
									externalProjection: new OpenLayers.Projection("EPSG:4326"),
									extractAttributes:true
				var kmlString=kmlFormat.write(select.features, true);
		map.addControl(control);
		control.activate();
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Export-vector-layer-featuers-as-kml-and-download-that-kml-file-tp6888418p6888418.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
