[OpenLayers-Dev] Re: OpenLayers 2.11 RC3
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Sat Sep 3 03:22:59 EDT 2011
Tim Schaub wrote:
> Regarding the fixed tickets listed as 2.12, I started changing those to
> 2.11, but it got very tedious.
> If anybody else wants to take some time, that would be helpful
I can make changes from 2.12 to 2.11 if the OpenLayers Team seems right that
I do it.
Question: Also should be placed 2.11 RC2 as version and delete estate?
What to do with #3456? reopen and set to Pullup or move to 2.12?
Xavier
Tim Schaub wrote:
> At this point, I'm most interested in seeing 2.11 released before
> FOSS4G. I think for that to happen, we need to call it good now.
> 2.11, but it got very tedious. If anybody else wants to take some time,
> that would be helpful (there's also
> http://trac-hacks.org/wiki/BatchModifyPlugin - I can vouch that it
> works, but there is liability in bringing on abandoned plugins).
> Tim
> On 9/1/11 6:16 PM, christopher.schmidt at nokia.com wrote:
>> On Sep 1, 2011, at 1:13 PM, ext Xavier Mamano (jorix) wrote:
>>> Hi,
>>> I think there are some mismatches between
>>> "root/branches/openlayers/2.11"
>>> and the Tickets:
>>> Tickets 2.11 with resolution fixed and *not applied* the branch 2.11
>>> http://trac.osgeo.org/openlayers/ticket/3456 is fixed, but not on branch
>>> 2.11.
>> This was not marked pullup, so it was not pulled into 2.11.
>> Tim, can you comment on whether you think this belongs in 2.11?
>>> (I think it's the only one in this situation,
>>> see "Modified" in
>>> http://trac.osgeo.org/openlayers/query?status=closed&order=changetime&col=id&col=summary&col=changetime&milestone=2.11+Release&desc=1&resolution=fixed)
>>> Tickets 2.12 with resolution fixed and *applied* the branch 2.11
>>> Tickets applied in the trunk before 08.08.2011 are also in 2.11 branch
>>> (excluding #3431, and #3352 fixed also by [12185]. See
>>> http://trac.osgeo.org/openlayers/log/branches/openlayers/2.11)
>>> The affected tickets are: #2247, #3440, #3433, #3438,, #3436, #3423,
>>> #3411,
>>> #3407 , #3412, #3400, #3387, #3393, #3368, #3375, #3349, #3367, #3366,
>>> #3365, #3354
>>> (see "Modified" in
>>> http://trac.osgeo.org/openlayers/query?status=closed&order=changetime&col=id&col=summary&col=changetime&milestone=2.12+Release&desc=1&resolution=fixed)
>> Yes, anything that was in before RC2 got into 2.11 because we
>> re-branched.
>> Anyone who wants to can move those tickets to 2.11 and update the release
>> notes; none of them are so crucial I intend to spend a lot of time
>> harping on them :)
>> -- Chris
>>> Xavier Mamano
>>> christopher.schmidt wrote:
>>>> The OpenLayers Development Team is proud to announce the third release
>>>> candidate of OpenLayers 2.11!
>>>> As of 2.11-RC3, the OpenLayers 2.11 release closes an additional 8
>>>> tickets,
>>>> resolving a small number of issues with the previous release candidate.
>>>> We invite you to help us test the 2.11 release candidate! To test 2.11
>>>> in your applications, include the following tag in your
>>>> OpenLayers-powered page:
>>>> As always, the source is available at http://openlayers.org/download/.
>>>> Bug reports can be filed in Trac, under the 2.11 RC3 version and 2.11
>>>> milestone.
>>>> Christopher Schmidt
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/OpenLayers-2-11-RC3-tp6722816p6750818.html
>>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>>> Dev mailing list
> Tim Schaub
> OpenGeo - http://opengeo.org
> Enterprise support for open source geospatial.
> Dev mailing list
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OpenLayers-2-11-RC3-tp6722816p6756079.html
More information about the Dev
