SV: SV: [OpenLayers-Dev] Command line Closure compiler and Windows
christopher.schmidt at nokia.com
Tue Sep 20 10:16:32 EDT 2011
On Sep 20, 2011, at 10:04 AM, ext Iversen Sverre wrote:
> Hi, version 2.7.2 worked but with warnings - warnings are related to
> OpenLayers code I guess.
Yep. These are expected warnings from closure. (There is some movement towards
actually getting full closure support out of the library, but we haven't made it
a priority yet.)
-- Chris
> Total files merged: 269
> Compressing using closure
> c:\docume~1\iverse~1\locals~1\temp\tmpwix5wc:13540: WARNING - Suspicious
> code. T
> his code lacks side-effects. Is there a bug?
> if (styleUrl && key == "highlight") {
> c:\docume~1\iverse~1\locals~1\temp\tmpwix5wc:33724: WARNING - variables,
> functio
> ns, and arguments cannot be deleted in ES5 strict mode
> delete child;
> c:\docume~1\iverse~1\locals~1\temp\tmpwix5wc:69679: WARNING - variables,
> functio
> delete iFrame;
> c:\docume~1\iverse~1\locals~1\temp\tmpwix5wc:69699: WARNING - variables,
> functio
> delete form;
> 0 error(s), 4 warning(s)
> Adding license file.
> Writing to OpenLayers-closure.js.
> Done.
> BR
> Sverre Iversen - thanks!
> -----Opprinnelig melding-----
> Fra: christopher.schmidt at nokia.com
> [mailto:christopher.schmidt at nokia.com]
> Sendt: 20. september 2011 15:49
> Til: Iversen Sverre
> Emne: Re: SV: [OpenLayers-Dev] Command line Closure compiler and Windows
> On Sep 20, 2011, at 9:20 AM, ext Iversen Sverre wrote:
>> Hi Christopher and thanks for quick response
>> I had the former version 2.5 so I installed version 3.2.2 but got a
>> different error message:
> Python 3 and Python 2 are two different programming languages; you can't
> run Python 2.x scripts on Python 3.x, and build.py has not been ported
> to
> Python 3.
> Grab the latest 2.x branch Python and try again.
> -- Chris
>> File "C:\My Documents\Web\openlayers\OpenLayers-2.11\build\build.py",
>> line 14
>> print "No jsmin"
>> SyntaxError: invalid syntax
>> Any clues? - familiar with the build.py script?
>> BR
>> Sverre
>> Sendt: 20. september 2011 14:27
>> Til: Iversen Sverre
>> Kopi: openlayers-dev at lists.osgeo.org
>> Emne: Re: [OpenLayers-Dev] Command line Closure compiler and Windows
>> You need to use a more modern version of Python to build with the
>> closure
>> compiler (2.6+, I believe.)
>> -- Chris
>> On Sep 20, 2011, at 7:58 AM, ext Iversen Sverre wrote:
>>> Hi, I downloaded Openlayers 2.11 Sep. 14. 2011
>>> Tried to use the closure compiler, but it returns an error from
> script
>> (build.py -c closure full OpenLayers-closure.js):
>>> Total files merged: 268
>>> Traceback (most recent call last):
>>> File "C:\My
>> Documents\Web\openlayers\OpenLayers-2.11\build\build.py", line 80, in
>> <module> build(args[0], args[1], options=options)
>>> File "C:\My
>> Documents\Web\openlayers\OpenLayers-2.11\build\build.py", line 60, in
>> build minimized = closure.minimize(merged)
>>> File "../tools\closure.py", line 10, in minimize ntf =
>> tempfile.NamedTemporaryFile(delete=False) TypeError:
>> NamedTemporaryFile() got an unexpected keyword argument 'delete'
>>> Question:
>>> Is it any workaround? - and if any, I need a prescription on how to
>> run it - not only references to alternative tools. I have used the
>> manual way up to now (paste via web), but will prefer the command line
>> method.
>>> Best Regards
>>> Sverre Iversen
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev
