[OpenLayers-Dev] wps protocol
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Sep 23 17:23:57 EDT 2011
having a look in to the OpenLayers trunk, there is implementation of
OpenLayers.Format.WPSCapabilities, DescribeProcess and Execute (I'll do
some tests againts various WPS servers, known to me now days).
How is the OpenLayers.Protocol supposed to be used (not implemented-yet,
or did not found any) ? According to API doc, Protocol is to be used
together with vector layers, for reading the features.
I had a look into WFS protocol, my impression is, that it is used for
GetFeature request exclusively.
I think, it would be good, to let the user proceed somehow
GetCapabilities-DescribeProcess-Execute chain.
In my current implementation, I create following set of classes
OpenLayers.WPS.Process
OpenLayers.WPS.ComplexPut (used for In- and Output)
OpenLayers.WPS.LiteralPut (used for In- and Output)
OpenLayers.WPS.BBoxPut (used for In- and Output)
The in/outputs do have getValue and setValue methods, as well as some
others, for easy manipulation with the process in and outputs.
Again, the OpenLayers.WPS.Process, several attributes and methods are
defined, so the user (coder) can easily manipulate with particular
process (including execution, adding in and outputs instances and so on).
The process could be configured either automatically (getcapabilities,
describeprocess) or by hand, for example:
var my_process = new OpenLayers.WPS.Process({
identifier: "buffer",
inputs: [
new OpenLayers.WPS.ComplexPut({
identifier: "data",
value: OpenLayers.Format.GML.v2.prototype.write(vlayer.getFeatures())
new OpenLayers.WPS.LiteralPut({
identifier: "size",
value: 20
outputs: [
identifier: "buffer"})
// defined earlier
my_server.addProcess(my_process);
// do the work, event will be fired
my_process.execute();
(hope, it is self-explaining)
So, questions:
Does it make sense to use OpenLayers.Protocol in this case? Shall we
write OpenLayers.Protocol.WPS.GetCapabilities, DescribeProcess, Execute
classes? Would it be acceptable, to add OpenLayers.WPS namespace to
OpenLayers base class? Do you (OpenLayers trunk-commiters, psc) want
more deeper support for OGC WPS in OpenLayers, than "just" the Format
reader ?
Thanks
Jachym
More information about the Dev
