[OpenLayers-Dev] Re: [WPS-dev] openlayers client tests
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Sep 26 10:15:48 EDT 2011
Hi
I'm really not gml expert - happy, when my tools are able to read the
file, I give to them,
but maybe OpenLayers-devs (forwarding) would have some idea about this
issue?
Jachym
On 24.9.2011 22:30, Markus Schneider wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> BTW,
> what do you think about OpenLayers sending gml:featureMembers as the
> root element of the input parameter?
> IMHO, this is rather bad GML practice, as it basically starts in the
> middle of a GML encoded object.
> I would prefer if the GML payload could be a complete FeatureCollection
> with a surrounding element. I think this should improve interoperability
> with WPS implementations / processes that use full-blown (and more
> restrictive) GML parsers.
> Best regards,
> Markus
> Am 24.09.2011 22:20, schrieb Jachym Cepicky:
>> Hi,
>> I had similar problem in PyWPS, so I can understand that issue. I"ll try
>> to have a look at that issue.
>> Just for the record, original author of OpenLayers.Format.WPS* is Bart
>> van den Eijnden, I'm working on the gui right now (ExtJS 3.x)
>> jachym
>> On 24.9.2011 22:15, Markus Schneider wrote:
>> Hi Jachym,
>> thanks for the quick response.
>> I found the reason for the problem with deegree. When validating the
>> request in Eclipse, it returns
>>>>> The content of element 'wps:ResponseForm' is not complete. One of
>>>>> '{"http://www.opengis.net/wps/1.0.0":ResponseDocument,
>>>>> "http://www.opengis.net/wps/1.0.0":RawDataOutput}' is expected.
>> If the empty ResponseDocument element is omitted from the request, it
>> works fine (it's optional in the schema). Alternatively, one can specify
>> the mandatory ResponseForm child elements:
>> <wps:ResponseForm>
>> <wps:ResponseDocument>
>> <wps:Output>
>> <ows:Identifier
>> xmlns:ows="http://www.opengis.net/ows/1.1">BufferedGML</ows:Identifier>
>> </wps:Output>
>> </wps:ResponseDocument>
>> </wps:ResponseForm>
>> Best regards and thanks for your work on the client (will have a look as
>> soon as I find the time),
>> Markus
>> P.S.: If a request doesn't work, deegree usually provides hints in the
>> ExceptionReport that point to the cause of the problem. For the original
>> request, it returns:
>> <?xml version='1.0' encoding='UTF-8'?>
>> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:schemaLocation="http://www.opengis.net/ows/1.1
>> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
>> version="1.1.0">
>> <ows:Exception exceptionCode="NoApplicableCode">
>> <ows:ExceptionText> At least one of following parameters is
>> required
>> but missing: [{http://www.opengis.net/wps/1.0.0}ResponseDocument,
>> {http://www.opengis.net/wps/1.0.0}RawDataOutput].</ows:ExceptionText>
>> </ows:Exception>
>> </ows:ExceptionReport>
>> Am 24.09.2011 21:26, schrieb Jachym Cepicky:
>>>>> Execute request attached (I suppose, something will be misconfigured at
>>>>> the client side, so please let me know)
>>>>> Tested on
>>>>> http://85.25.95.86:8080/wps-bakeoff-2011/services
>>>>> and
>>>>> http://geoprocessing.demo.52north.org:8081/wps/WebProcessingService
>>>>> Jachym
>>>>> On 24.9.2011 21:21, Markus Schneider wrote:
>>>>> Hi Jachym,
>>>>> cool news!
>>>>> I would like to understand what's wrong with deegree here (and maybe
>>>>> it's even the same with 52 North). Could you send me the XML Execute
>>>>> request that fails?
>>>>> Best regards,
>>>>> Markus
>>>>> Am 24.09.2011 03:26, schrieb Jachym Cepicky:
>>>>>>>> Hi,
>>>>>>>> I have written simple test page, which will test the new
>>>>>>>> OpenLayers.Format.WPS* classes on each server, I have access to. Here
>>>>>>>> are some results.
>>>>>>>> So far, tested only Deegree, 52North, Geoserver and Zoo (I know their
>>>>>>>> public address), PyWPS (I have it on localhost, public server does
>>>>>>>> not
>>>>>>>> work now).
>>>>>>>> Results:
>>>>>>>> GetCapabilities: all passed
>>>>>>>> DescribeProcess (buffer): all passed
>>>>>>>> Execute (gml 3.1 input):
>>>>>>>> pywps and zoo did well,
>>>>>>>> geoserver returned correct exception (expecting Geometry, not
>>>>>>>> Feature),
>>>>>>>> 52North and Deergree failed (Error 500)
>>>>>>>> I think, that is great result!
>>>>>>>> Hints:
>>>>>>>> Geoserver
>>>>>>>> Why do you accept only geometry, not FeatureMember as input ?
>>>>>>>> Deegree and 52north
>>>>>>>> I have no idea, why I got HTTP Error 500: Internal Server Error
>>>>>>>> you can see the input POST execute request in firebug, when you
>>>>>>>> run the
>>>>>>>> test
>>>>>>>> the problem can be also on OpenLayers side
>>>>>>>> Howto
>>>>>>>> 1) Copy the attached document to OpenLayers (2.11+)
>>>>>>>> examples/directory
>>>>>>>> 2) adjust OpenLayers.ProxyHost (at the beginning of the "init"
>>>>>>>> function)
>>>>>>>> to where your script lives
>>>>>>>> 3) open in firefox, open firebug (or equivalent tools), hit the
>>>>>>>> button
>>>>>>>> and watch
>>>>>>>> 4), Oh, I nearly forgot to mention, you need to fix one small
>>>>>>>> issue in
>>>>>>>> OpenLayers, patch attached
>>>>>>>> http://trac.osgeo.org/openlayers/ticket/3517
>>>>>>>> We can now drop support for pywps/WPS.js :-) Let there be only the
>>>>>>>> *one*
>>>>>>>> OpenLayers-based WPS client.
>>>>>>>> Jachym
>>>>>>>> _______________________________________________
>>>>>>>> WPS-dev mailing list
>>>>>>>> WPS-dev at lists.opengeospatial.org
>>>>>>>> https://lists.opengeospatial.org/mailman/listinfo/wps-dev
> Markus Schneider
> l a t / l o n GmbH
> Aennchenstrasse 19 53177 Bonn, Germany
> phone ++49 +228 184960 fax ++49 +228 1849629
> http://www.lat-lon.de http://www.deegree.org
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk5+PeAACgkQLM5hjXxU/E7s9wCdFeQ9ed9/JMec0voxbAvW8s+r
> sqAAoIC4isdSTJqFBJljcVQxIqtksJvh
> =gJjt
> -----END PGP SIGNATURE-----
More information about the Dev
