[OpenLayers-Dev] OL build: Why put in the code compressed code
deprecated?
Marc Jansen
jansen at terrestris.de
Tue Sep 27 02:17:41 EDT 2011
Hi all,
I am also +1 on having "-deprecated" files whereever possible.
A simple but very good idea, both for having smaller builds and
educating users to change client code to be independant of deprecated code.
Best regards,
Marc
On 25.09.2011 13:38, Xavier Mamano (jorix) wrote:
> Hi,
> In OL exists code labeled as *Deprecated* but it is not possible to
> exclude deprecated code in compressed code, examples: "Util.js",
> "BaseTypes/Class.js", "BaseTypes/Element.js" ...
> If these source files are split into two, for example "Util.js" and
> "Util-deprecate.js" (with "@requires OpenLayers/Util.js"), so could easily
> create configuration files to exclude deprecated code.
> NOTE: In the far future the advanced optimization of "Closure Compiler"
> can also help, but not in the medium term.
> Xavier Mamano
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/OL-build-Why-put-in-the-code-compressed-code-deprecated-tp6828967p6828967.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev
