[OpenLayers-Dev] Re: Grid Image applyBackBuffer createBackBuffer - Please explain
Tim-Hinnerk Heuer th.heuer at gmail.com
Tue Apr 3 01:28:38 EDT 2012
Hi Again,
Already solved this by simply copying the code from the Tile.Image class
and changing the code needed. I'm not sure now if I should inherit from
Tile or from Image. At the moment I'm extending Tile. I guess it is more
general that way and likely not break as easily, but please let me know if
you have a strong argument for a Video Tile not to extend Tile but Image.
Thanks,
Tim
++Tim Hinnerk Heuer++
Twitter: @timhheuer
Blog: http://www.thheuer.com
On Tue, Apr 3, 2012 at 3:19 PM, Tim-Hinnerk Heuer <th.heuer at gmail.com>wrote:
> Hi,
> Working on the VideoWMS, I am a bit stuck now on this (mysterious) back
> buffer code. Basically an upgrade of OpenLayers broke my code. I am reading
> the code to understand it, but a simple explanation of what it is and does
> would be greatly appreciated so that I don't break things accidentally.
> Ultimately I would like to get the VideoWMS stuff into the trunk at some
> stage and am always merging with master to stay up to date with it here. I
> think given some interest it would be a good contribution.
> The problem, I think, is that I extended Tile.Image instead of Tile. So,
> I'm working on extending Tile instead of the more specific Image class.
> However, the Grid class also calls applyBackBuffer and in
> turn createBackBuffer on all the Tiles. Should this really be in Grid? What
> is done to render the tiles?
> Please enlighten me.
> Thanks,
> Tim
> Twitter: @timhheuer
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120403/6ddbd6a1/attachment.html
More information about the Dev mailing list
