[OpenLayers-Dev] Re: Why "firebugx.js" is in "OpenLayers.js" compressed code?
Xavier Mamano (jorix) xavier.mamano at gmail.com
Sun Apr 8 05:56:52 EDT 2012
Hi Eric,
>See ...
Ok, "tests.cfg" has the advantage of showing the ability to
internationalize. IMHO would be desirable to remove Firebug also from
"tests.cfg"
NOTE: I think Firebug/firebug.js and Firebug/firebugx.js are obsolete, more
than four years without changes (other than add a semicolon and a closure)
And *Firebug/readme.txt* says "When this issue is resolved, Firebug Lite can
be used directly - no further modifications are needed for OpenLayers" so...
> I don't know why console.log does not work, it's a pity.
This is because "console.firebug" is undefined (on FF+Firebug, IE9 and
Chrome consoles) , therefore "firebugx.js" (it is exported after
"firebug.js") converts all functions of the console to void functions.
Regards,
Xavier
erilem wrote
> On Sat, Apr 7, 2012 at 12:50 PM, Xavier Mamano (jorix)
> <xavier.mamano@> wrote:
>> Hi,
>> I saw that "console" does not work after load
>> "http://www.openlayers.org/dev/OpenLayers.js".
>> Searching "!window.console" in the compressed code can see that
>> "Firebug/firebug.js" and "Firebug/firebugx.js" are included, oops!
>> Why? ("Firebug" is properly excluded from "full.cfg")
> See
> <https://github.com/openlayers/openlayers/commit/fa15785c9631a9f54b001058906cc51badb86f4d>.
> I don't why console.log does not work, it's a pity.
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine@
> http://www.camptocamp.com
> Dev mailing list
> Dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
View this message in context: http://osgeo-org.1560.n6.nabble.com/Why-firebugx-js-is-in-OpenLayers-js-compressed-code-tp4694879p4708066.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
