[OpenLayers-Dev] Bug in OpenLayers Bing support for data
attribution
Eric Blasenheim
eric.blasenheim at pb.com
Tue Apr 10 07:46:02 EDT 2012
Thanks, Bart.
What is the process for reviewing and/or checking in the fix?
Eric
From: Bart van den Eijnden [mailto:bartvde at opengeo.org]
Sent: Tuesday, April 10, 2012 3:34 AM
To: Eric Blasenheim
Cc: openlayers-dev at lists.osgeo.org
Subject: Re: [OpenLayers-Dev] Bug in OpenLayers Bing support for data attribution
Thanks for your detailed report Eric.
I've opened up:
https://github.com/openlayers/openlayers/issues/398
so that we don't forget about this issue.
Best regards,
Bart
OpenGeo - http://opengeo.org<http://opengeo.org/>
Expert service straight from the developers.
On Apr 9, 2012, at 4:25 PM, Eric Blasenheim wrote:
I am brand new to this list and the site so I was hoping for some suggestions in getting a bug in the Bing Maps data Attribution checked in.
The bug that I found was that when your entire map is west of -90 or east of +90, no text attribution shows up. I have attached a picture but this is easily reproducible athttp://openlayers.org/dev/examples/bing-tiles.html . (It's also probably not a good idea to leave out attribution when you view the providers home location of Seattle.)
The fix seems to be a very simple change that forces the code to handle the fact that the JSON response from the Imagery Metadata call for the bounding boxes is lat/lon and not Lon/lat.
For example:
bbox=27, -179.99, 87, -126.5 is clearly two lat/lon rather than lon/lat pairs.
I discovered that the existing code was not passing the "reverseOrder" flag to "OpenLayers.Bounds.fromArray". Just adding missing second parameter of "true" allows the code to generate bounding boxes consistent with the rest of Open Layers and the bug is fixed. The line below with the added parameter is from Bing.js.
bbox = OpenLayers.Bounds.fromArray(coverage.bbox, true);
Normally, I do not like hard coding "true" or any constants if there is a different way but in this case, I see no way expressing that the JSON data order returned from the Microsoft call is what it is.
Of course, this also means that the attribution was not correct in many places even when it did show up.
As I am not familiar with the processes used for validation or testing but I hope I will hear from someone soon.
Thanks in advance,
Eric Blasenheim
Dev mailing list
Dev at lists.osgeo.org<mailto:Dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120410/51d90435/attachment-0001.html
More information about the Dev
