[OpenLayers-Dev] Shapefiles, Again
Carsten Eider
eider at fh-bingen.de
Tue Apr 10 13:39:20 EDT 2012
>From my point of view a shape-importer based on js does not make any sense.
First you will have to unzip a file to get at least the three relevant
shapefiles and then you would have to
examine these non text higly binary files. sorry this is stuff a browser
was designed for.
Maybe ogr2ogr (http://www.gdal.org/index.html) may help you to convert
your files
- Carsten
Am 10.04.2012 18:06, schrieb Arnie Shore:
> I wonder if there's any recent dev't work underway re handling
> shapefiles in some manner. (Nothing promising showed up in my googling.)
> This wd presumably be through some JS library, and sans any geo-server
> participation. I'm using
> .OSM("MyBase", my_Path + "${z}/${x}/${y}.png") for tile access in a
> fairly lightweight open source application, and I want to avoid a
> server requirement.
> A converter of some type would also work for me here, absent the
> above's availability.
> Thanks for any information, folks!
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev
