[OpenLayers-Dev] addOptions and redraw
Bart van den Eijnden
bartvde at opengeo.org
Wed Apr 11 08:49:43 EDT 2012
Another related question to my previous post.
So I've worked around the previous issue by clearing alwaysInRange before calling addOptions.
Then when I pass in minScale and maxScale options to addOptions that effectively will make the layer be out of scale, nothing happens, even after calling redraw.
Am I missing something here? Why is the layer not turned off in this case, it only happens if I don't call redraw and manually pan the map.
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120411/6fd0f67b/attachment-0001.html
More information about the Dev
