[OpenLayers-Dev] addOptions and redraw
Bart van den Eijnden
bartvde at opengeo.org
Wed Apr 11 09:48:35 EDT 2012
Hey Eric,
right, what I am doing now is calling display in the following way:
layer.display(layer.calculateInRange());
but it feels a bit weird to do it this way.
With out of sync I mean indeed being displaced, so that's similar to what your github issue describes. Thanks for the pointer I'll check that out.
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Apr 11, 2012, at 3:41 PM, Eric Lemoine wrote:
> On Wednesday, April 11, 2012, Bart van den Eijnden wrote:
> Hey Eric,
> thanks for your quick replies being at FOSS4GNA.
> I wasn't, and mainly because I was looking at Layer.js where redraw has no argument:
> https://github.com/openlayers/openlayers/blob/master/lib/OpenLayers/Layer.js#L553
> But I see HTTPRequest has the boolean argument:
> https://github.com/openlayers/openlayers/blob/master/lib/OpenLayers/Layer/HTTPRequest.js#L146
> But I should not have to call force to get the layer to hide if it's out of scale right?
> Right. I initially thought you needed to reload images.
> "force" places a random value in the query string. This is to "break" the cache.
> Have you tried calling layer.display()?
> Force is just to always fetch a new image from the server.
> However, calling redraw(true) does not make the layer disappear unfortunately.
> When zooming the overlay is also out of sync with the basemap, not sure if this is directly related to the redraw call though.
> Sorry I'm not sure I understand what you mean by "out of sync".
> You may be hit by <https://github.com/openlayers/openlayers/pull/393>.
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120411/209e85e7/attachment-0001.html
More information about the Dev
