[OpenLayers-Dev] addOptions and redraw
Bart van den Eijnden bartvde at opengeo.org
Thu Apr 12 04:57:16 EDT 2012
To finally end this thread, I was unable to reproduce the displacement in a plain OpenLayers example.
If I swap the Google base layer in GXP with Bing all is fine, so it must be related to the GXP-Google combination.
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Apr 12, 2012, at 10:04 AM, Bart van den Eijnden wrote:
> Ofcourse this is not a solution either, since the layer will not automatically turn on again, and it will be unchecked in a layer manager.
> Best regards,
> Bart
> On Apr 12, 2012, at 9:31 AM, Bart van den Eijnden wrote:
>> Hi Eric,
>> the displacement issue was caused by calling display on the layer.
>> If I use setVisibility all is fine.
>> layer.setVisibility(layer.calculateInRange());
>> I'll open up a ticket for the alwaysInRange issue.
>> Best regards,
>> Bart
>> On Apr 11, 2012, at 7:43 PM, Bart van den Eijnden wrote:
>>> Just tested, using map.setCenter() does not work.
>>> I guess it's because the code block is protected by zoomChanged and centerChanged, and none of them changed in this case.
>>> https://github.com/openlayers/openlayers/blob/master/lib/OpenLayers/Map.js#L1934
>>> Would it not make sense to move this logic (visibility based on range) from the Map into the Layer? Ofcourse I am unaware of the history of all this.
>>> I'll work on creating a minimal example to illustrate the issues first thing tomorrow morning.
>>> Best regards,
>>> Bart
>>> On Apr 11, 2012, at 6:37 PM, Eric Lemoine wrote:
>>>> On Wed, Apr 11, 2012 at 4:26 PM, Eric Lemoine
>>>> <eric.lemoine at camptocamp.com> wrote:
>>>>> On Wed, Apr 11, 2012 at 3:48 PM, Bart van den Eijnden
>>>>> <bartvde at opengeo.org> wrote:
>>>>>> Hey Eric,
>>>>>> right, what I am doing now is calling display in the following way:
>>>>>> layer.display(layer.calculateInRange());
>>>>>> but it feels a bit weird to do it this way.
>>>>> Yes, that's ugly. We really provide a better way to handle your case.
>>>> Another thing you could try is call map.setCenter() (with no
>>>> argument), this should turn off your out-of-range overlays.
>>>> Regarding the displacement issue I'm interested to exactly know how to
>>>> reproduce it.
>>>> Eric Lemoine
>>>> Camptocamp France SAS
>>>> Savoie Technolac, BP 352
>>>> 73377 Le Bourget du Lac, Cedex
>>>> Tel : 00 33 4 79 44 44 96
>>>> Mail : eric.lemoine at camptocamp.com
>>>> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120412/b6c152fc/attachment-0001.html
More information about the Dev mailing list
