[OpenLayers-Dev] Help with where to look for a bug - drawFeatures controls not working at ONE zoom level.
Matt Priour mpriour at kestrelcomputer.com
Thu Apr 26 00:07:16 EDT 2012
you should file this as a bug on github [1] and submit your custom
crossing handling code as well.
[1] https://github.com/openlayers/openlayers
Matt Priour
On 4/25/2012 10:10 PM, Phil Scadden wrote:
> Looking further, I see that the layer for drawing on is create with this
> code in RegularPolygon.js
> activate: function() {
> var activated = false;
> if(OpenLayers.Handler.Drag.prototype.activate.apply(this, arguments)) {
> // create temporary vector layer for rendering geometry sketch
> var options = OpenLayers.Util.extend({
> displayInLayerSwitcher: false,
> // indicate that the temp vector layer will never be out of range
> // without this, resolution properties must be specified at the
> // map-level for this temporary layer to init its resolutions
> // correctly
> calculateInRange: OpenLayers.Function.True,
> wrapDateLine: this.citeCompliant
> }, this.layerOptions);
> this.layer = new OpenLayers.Layer.Vector(this.CLASS_NAME, options);
> this.map.addLayer(this.layer);
> activated = true;
> return activated;
> It is picking up wrapdateline from citeCompliant.
> Now if I set citeCompliant to true, then you cant draw a polygon that
> crosses the 180 - so it is set to false, and I have special code
> handling the crossing. This looks like a catch-22.
> Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2012.0.1913 / Virus Database: 2411/4959 - Release Date: 04/25/12
More information about the Dev mailing list
