[OpenLayers-Dev] Fractional Zoom with Grid layers - Artifacts
James Lamanna
james at touchtable.com
Fri Aug 3 10:04:20 PDT 2012
I'm working on an application that requires that there be fractional
zoom capability for almost all layers.
I've been working with some XYZ layers with fractionalZoom (by setting
serverResolutions), however, I noticed that there are nasty white
grid-line artifacts that show up when on non integral zoom levels.
Upon reviewing what is going on, the artifacts are generated as a result
of scaling the layer <div>. I believe that this approach should be
changed to scale the tile images, rather than the layer div.
So, transformDiv() would have code in it like this:
transformDiv: function(scale) {
$(this.div).find('img').css('width',
function(i,v){ return v * scale; });
$(this.div).find('img').css('height',
function(i,v) { return v * scale; });
$(this.div).find('img').css('left',
function(i, v) { return v * scale; });
$(this.div).find('img').css('top',
This appears to remove the tile artifacts.
Thanks.
-- James
More information about the Dev
