[OpenLayers-Dev] Bug with Wrap date line & vertors
Andreas Hocevar
ahocevar at opengeo.org
Thu Aug 9 00:44:27 PDT 2012
this may be a combination of the coordinates generated by the
DrawFeature control and the map viewport you are looking at. If you
persist your geometries to a server and make sure that the coordinates
are normalized (longitude of -180 to +180, only exceeding +180 for
geometries that actually cross the dateline), you should get good
results.
Andreas.
On Thu, Aug 9, 2012 at 7:22 AM, Gael Lafond <G.Lafond at aims.gov.au> wrote:
> Hello group,
> I know, there has been a lot of work around this kind of issues, but I still have some issue with the latest stable build (2.12).
> The bug I'm having is easy to reproduce:
> 1. Take the draw-feature.html example
> 2. Set the wrapDateLine attribute to true
> (line 31) "http://vmap0.tiles.osgeo.org/wms/vmap0?", {layers: 'basic'}, {wrapDateLine: true});
> 3. Load the draw-feature.html page in a browser (I try it with both FF and Chrome)
> 4. Zoom out as much as possible, to see almost the whole world
> 5. Draw about 10 squares (using "draw box"), touching each other, to cover all the whole equator. Any polygon would do, it's just easier to see with squares / rectangles.
> 6. Pan around from East to West (or West to East)
> I would expect to see squares all around the equator, where ever I pan. But sometime, quite often actually, some squares are missing, up to half of them. Panning up and down do not make them to re-appear. If I pan a little bit more to the side where squares are missing, suddenly all the missing squares appear, covering the whole equator. Panning to where the map was do not make the squares to re-disappear.
> The bug occur at any zoom level, but it's more stable and easier to reproduce when (almost) the whole world is visible.
> It seems to be a bug related to the date line since the missing polygons are usually from 0 to 180 or from -180 to 0, and having wrapDateLine: false fix it.
> I played around with the wrapDateLine: false and it fixed the bug, but it's not a solution since the point of interest of my map is Australia and the pacific ocean. I need the wrapDateLine: true.
> I think one solution would be make a copy of all polygons, with 360 degrees offset, to be sure to always see at lease one copy (I haven't tried it yet), but I think this solution will double the resources usage of the layer and (most of the time) double the opacity of the semi-transparent styles.
> Is anyone have ever found a solution / work around for this?
> Thanks
> ________________________________________
> Gael Lafond
> Programmer
> Australian Institute of Marine Science
> PMB 3
> Townsville MC
> QLD 4810
> Ph 4753 4116
> g.lafond at aims.gov.au
> The information contained within this transmission is for the
> use of the intended recipient only and may contain confidential
> and/or legally privileged material and/or material the subject
> of copyright and/or personal information and/or sensitive
> information that is subject to the Privacy Act 1988. Any review,
> re-transmission, disclosure, dissemination or other use of, or
> taking of any action in reliance upon, this information by
> persons or entities other than the intended recipient is
> prohibited. If you have received this email in error please
> notify the AIMS Privacy Officer on (07) 4753 4444 and delete
> all copies of this transmission together with any attachments.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
