[OpenLayers-Dev] v2.11 = 48.501558 , v2.12 = 48.50155799999999
midi
info at digitale-wegeverwaltung.de
Wed Aug 22 06:21:32 PDT 2012
Hello group,
first of all, thanks to all devs for the excellent work.
We have a very large GIS App developed with 2.10 / 2.11.
The UI was made with jQuery 1.6.1.
No MapServer,GeoServer,WMS,WFS ... only xyz-Tiles and a Vector-Layer.
The Vector Layer is large but only lines and points.
After switch to 2.12 everthing works fine,
but in the result of
new OpenLayers.Format.WKT ( myobj ).write ( myfeatures , true );
new OpenLayers.Format.KML ( myobj ).write ( myfeatures , true );
new OpenLayers.Format.GML.v2 ( myobj ).write ( myfeatures , true );
new OpenLayers.Format.GML.v3 ( myobj ).write ( myfeatures , true );
new OpenLayers.Format.GeoJSON ( myobj ).write ( myfeatures , true );
new OpenLayers.Format.OSM ( myobj ).write ( myfeatures , true );
new OpenLayers.Format.GPX ( myobj ).write ( myfeatures , true );
myobj = {'internalProjection': map.baseLayer.projection,
'externalProjection': new OpenLayers.Projection("EPSG:4326");};
every 'lat' Value has 14 decimals (48.50155799999999)
every 'lng' Value is Ok with 6 decimals
switching back to 2.11 (except GPX write, which doest not exist in 2.11)
every 'lat' value has 6 decimals.
every 'lng' value has 6 decimals.
why has only the 'lat' value 14 decimals and the 'lng' 6 decimals ?
if there rounding problems this should be both in 'lat' and 'lng'.
any ideas ?
View this message in context: http://osgeo-org.1560.n6.nabble.com/v2-11-48-501558-v2-12-48-50155799999999-tp4997040.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
