[OpenLayers-Dev] Is it possible to make a mask layer ?
Marc Jansen jansen at terrestris.de
Wed Aug 22 13:15:16 PDT 2012
Hi Julien,
your question might better fit on the users list, but I'll answer anyway.
You could try to add a Vector layer with a polygon-feature that is style
partly-opaque; this shoukd do the trick if I got you right.
Further questions should possibly be sent to
openlayers-users at lists.osgeo.org.
Best regards,
Marc
On 21.08.2012 11:54, julienfouilhe wrote:
> Hello everyone,
> I have to do something at work now but I don't even know if it's possible. I
> am currently displaying an image layer like this :
> http://osgeo-org.1560.n6.nabble.com/file/n4996595/33.png 33.png
> I would like to be able to hide some parts of the image to display the map.
> Is it possible to display a layer above the image which would do that, or
> any other solution ?
> Thanks for your help.
> Julien Fouilhé.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Is-it-possible-to-make-a-mask-layer-tp4996595.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
