[OpenLayers-Dev] Rework of Google layer leads to map div transparency
Andreas Hocevar ahocevar at opengeo.org
Fri Dec 7 15:57:06 PST 2012
Hey Denis,
try to set the <!DOCTYPE html> doctype in your document, instead of
using a HTML4 doctype. If that doesn't work, you have to set the
following css:
.olForeignContainer { opacity: 1 !important; }
Let us know which one works for you.
Thanks,
Andreas.
On Fri, Dec 7, 2012 at 4:34 PM, Denis Rykov <rykovd at gmail.com> wrote:
> Hi, Bart!
> Sorry I can't provide minimal example, but my code is very simple.
> Please take a look: http://tinyurl.com/cgblaad
> On Fri, Dec 7, 2012 at 4:08 PM, Bart van den Eijnden <bartvde at opengeo.org>
> wrote:
>> Can you show us a minimal example to reproduce?
>> Best regards,
>> Bart
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> On Dec 7, 2012, at 3:35 AM, Denis Rykov <rykovd at gmail.com> wrote:
>> After recent rework of Google layer - in my application transparency of
>> all elements of map div (including wms layers, pan-zoom buttons) becomes
>> about 50%. Switching back from dev/OpenLayers.js to api/OpenLAyers.js solves
>> the problem. _______________________________________________
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Dev mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
More information about the Dev mailing list
